HP Zbook 14 Mobile Workstation (G1)
  • lepe
    • Dec 2018
    • 7
    • Japan
    I got a laptop with BIOS password protected.
    Model details:
    Product ID: E2P27AV
    The dump is attached (contains password).
    The the official BIOS can be downloaded from the HP site.
    NOTE: After 3 attempts there is no hash.
    Thank you in advance.
  • Andrew_R
    Banned
    • Jun 2018
    • 91
    • Poland
    Re: HP Zbook 14 Mobile Workstation (G1)
    Model details:
    Product ID: E2P27AV
    Read backup again , this file is damaged.
    • lepe
      • Dec 2018
      • 7
      • Japan
      Thank you. I will dump it again. I will post it soon.
      • lepe
        • Dec 2018
        • 7
        • Japan
        This is the correct dump. I didn't verified several times the first time (sorry).
        • lepe
          • Dec 2018
          • 7
          • Japan
          I found a dump in this forum for a similar model and after flashing it the password is gone but now I'm getting a warning: "not commited state". Should I need a "better"(more suitable for my laptop) bios image or is there any other way to remove that warning?
            • 22286
            Your bios pass removed .
            • lepe
              • Dec 2018
              • 7
              • Japan
              @SMDFlea: Thanks! I tried and no more warning, but its asking me to update the Bios. I think I can do that later. Great!
              I would really like to learn how to do it, so I can help others in the same way you did. Is there any tutorial on that?
              • hawara
                • Oct 2022
                • Maroc
                HP Zbook 14
                HP Zbook 14 :
                Plz anyone can able to remove password from BIOS?
                • hardware1
                  • Sep 2021
                  • 2949
                  • N/A
                  Re: HP Zbook 14
                  Originally posted by hawara
                  HP Zbook 14 :
                  Wrong chip. look for another chip it could be 16mb.
                  all donations are welcome,
                  • mrwab
                    Banned
                    • Jan 2014
                    • 83
                    • morocco
                    this model have 16mo bios chip
                    • perfm2
                      • Nov 2019
                      • 33
                      • usa
                      Would someone be kind enough to remove the BIOS password on this one for me? Thanks!!
                      • hardware1
                        • Sep 2021
                        • 2949
                        • N/A
                        Here's your Unlocked Bios, Next time you can use RCUnlocker tool.
                        • perfm2
                          • Nov 2019
                          • 33
                          • usa
                          Thank you so much!
                          • perfm2
                            • Nov 2019
                            • 33
                            • usa
                            So we got the BIOS unlocked but I'm getting the "machine not in committed state" warning during boot and it definitely has a long hesitation/pause before showing the blue HP logo screen.
                            I double checked all the identity info in the BIOS and serial # etc all seem to match.
                            DMIFIT tells me MPM is locked.
                            Any ideas from anyone? I'm guessing for some reason the UUID changed or I need to generate a new one?
                            • hardware1
                              • Sep 2021
                              • 2949
                              • N/A
                              Try this one.
                              • perfm2
                                • Nov 2019
                                • 33
                                • usa
                                Got this installed and got all the HP "Not for production BIOS" warnings. Then I followed the instructions that had the laptop self propagate all of the needed fields and lock the MPM.
                                I assume that was the right procedure to follow?
                                It populated all the fields and identifiers as before, but still shows Machine not in committed state.
                                Then it refused to launch back into Win 10. Either from the drive I had running on it, or from my UFEI USB image to reinstall.
                                The Windows loading dot circle shows up but just spins, walked away for more than 30 mins and just nothing happens now.
                                Going to give up and just pitch this little guy. It's sleek, but the hardware isn't anything to rave about and it's also got this unique issue I've never come across.
                                It cuts it's power after about 10 seconds every other boot. No matter what state it's in. Every other boot, power just cuts out.
                                I've stripped it down to just a motherboard and stick of ram. Every other boot.....power cuts out.
                                While I'm gonna trash it, the power cut thing really fascinates me, I can't wrap my heard around what could be wrong with it.
                                • zmezm1995`
                                  • Nov 2020
                                  • 99
                                  • iraq
                                  need bios hp zbook 14 g1
                                  board number 6050A2559101 -MB-A03
                                  Serial CNU434B7JX
                                  Laptop problem no display
                                  and this my dump
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12441
                                    Serial CNU434B7JX
                                    and this my dump
                                    HP ZBook 14 Mobile Workstation
                                    • zmezm1995`
                                      • Nov 2020
                                      • 99
                                      • iraq
                                      same thing
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12441
                                        same thing
                                        Find hardware issues
                                          HP ZBook ZBook 17 G4 Mobile Workstation Mobile workstation 17 Specification for Upgrade or Repair
                                          This specification for the HP ZBook ZBook 17 G4 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 17 G4 Mobile Workstation boardview and ZBook 17 G4 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 05:35 AM
                                          HP ZBook ZBook 17 G3 Mobile Workstation Mobile workstation 17 Specification for Upgrade or Repair
                                          This specification for the HP ZBook ZBook 17 G3 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 17 G3 Mobile Workstation boardview and ZBook 17 G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 05:30 AM
                                          HP ZBook ZBook 15u G3 Mobile Workstation Mobile workstation 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook ZBook 15u G3 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 15u G3 Mobile Workstation boardview and ZBook 15u G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-07-2024, 05:20 AM
