BIOS bin file for Dell latitude 7480
  • mouez_by
    • Sep 2013
    • 14
    Re: BIOS bin file for Dell latitude 7480
    please Help ,if you can repair bios file,i think corrupted ,start and stop after two second without display
    Latitude 7480
    Service TAG: 2BQPPN2
    CAZ20 LA-E131P
    Rev:2.0(a01)
    2017-10-13
    I attach my dump
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      #182
      Originally posted by mouez_by
      please help ,if you can repair bios file,i think corrupted ,start and stop after two second without display
      latitude 7480
      service tag: 2bqppn2
      caz20 la-e131p
      rev:2.0(a01)
      2017-10-13
      i attach my dump
      here is your new dump
      wait five mnt let it restart several times
      • JAFATAGNA
        • Apr 2016
        • 59
        • MARRAKECH
        #183
        Originally posted by farouk_1994
        Try this clean me file
        THANKS FOR REPLAY problem not solved SAME
        • mouez_by
          • Sep 2013
          • 14
          Thanks but same problem START FOR 1-2S AND STOP
          • kiensgpro
            Badcaps VIETNAM
            • Nov 2021
            • 17
            #185
            Helpme TPM device is not detected
            SERVICE: BJZ23M2
            • hanah
              • Mar 2018
              • 12
              • india
              #186
              Pls fix this la-e131p
              tpm erorr
              • jaisharma7464
                • Mar 2023
                • 6
                • india
                #187
                Tpm error az20 la-e131p rev:1.0 (a00) need bios
                • hussaka
                  • Jan 2015
                  • 154
                  • italy
                  #188
                  thank you so much mrwab
                  • JAFATAGNA
                    • Apr 2016
                    • 59
                    • MARRAKECH
                    #189
                    HI i think bios is corrupted. Laptop turn on AND instantly TURN OFF
                    PLZZ REPAIR
                    • Neeck
                      • Sep 2023
                      • 6
                      • Italy
                      #190
                      Re: Remove Computrace Dell Latitude 7480
                      Hi, I wanted to try disabling computrace from my Dell Latitude 7480 and I think I need a different bios version (without computrace). If there is any other block like Intel ME, I would like that to be removed too.
                      My service tag is: 8YW4VT2
                      The notebook model is CAZ20 LA-E131P Rev 1.0(A00).
                      In the attachment I send both files that I obtained from the motherboard (using the CH341A).
                      Many thanks in advance!
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12347
                        #191
                        Latitude 7480
                        Service Tag: 8YW4VT2
                        • Neeck
                          • Sep 2023
                          • 6
                          • Italy
                          #192
                          Originally posted by hoaca388
                          Latitude 7480
                          Omg! It worked! You were very kind, I would really like to have your ability.
                          To be safe, I had removed my SSD (which I think had computrace, correct me if I'm wrong), should I format it before mounting it or should I change it?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12347
                            #193
                            I don't know but it's me ,i will format.
                            • Neeck
                              • Sep 2023
                              • 6
                              • Italy
                              #194
                              Hi, it's still me. Since the process worked perfectly yesterday, I plan to do the same with my sister's 7480.
                              So please can you remove computrace from this too?
                              Service Tag: DVYJNH2
                              The notebook model is CAZ20 LA-E131P Rev 2.0(A01)
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12347
                                #195
                                Latitude 7480
                                • Neeck
                                  • Sep 2023
                                  • 6
                                  • Italy
                                  #196
                                  Latitude 7480
                                  Thanks so much, that worked too!
                                  You are a real magician!
                                  • dqtech
                                    Badcaps
                                    • Jul 2018
                                    • 639
                                    • N/A
                                    #197
                                    thanks
                                    • gerlach
                                      • Jan 2020
                                      • 15
                                      • Poland
                                      #198
                                      Hello.
                                      I have a problem with my password.
                                      The generated string
                                      RCMzCBC2s1ZRbncC
                                      based on 1XTG7S2-6FF1 it
                                      unfortunately it didn't work.
                                      Latitude 7480
                                      Service TAG: 1XTG7S2
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12347
                                        #199
                                        Originally posted by gerlach
                                        Hello.
                                        RCMzCBC2s1ZRbncC
                                        Latitude 7480
                                        https://www.badcaps.net/forum/showpo...42&postcount=4
                                        • gerlach
                                          • Jan 2020
                                          • 15
                                          • Poland
                                          #200
                                          THX . It,s ok.
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
                                            DELL Latitude 7480 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7480 boardview and 7480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7480...
                                            09-06-2024, 08:01 AM
