LENOVO IDEAPAD 300S-11ibr issues
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model" Lenovo Ideapad 300S-11iBR
    platform:BM5488_FPC_V1.4
    It came with no display. I downloaded lenovo bios update and extracted main+EC from it. After flashing i get display after almost a minute but still it gets stuck at Lenovo logo. The system seems to hangs at startup logo as usb kbd also refuses to work at that point. Can it be a TXE region issue. I tried cleaning txe region but ended with no display-might be 'coz of my inexperience with txe region. It uses TXE 2.0.2.2092 firmware.
    I'm attaching the firmware from lenovo update+ my cleaned txe main bios. can anybody fix this??
    PS: The mb is same as LENOVO FLEX 3-11_BM5488_FPC_V1.4
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LENOVO IDEAPAD 300S-11ibr issues
    Forgot to tell you, i tried flex 3-11 bios also but problem remains same.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Here are the tools to do it, if anybody dont have it already
        • 20318
        Try this one.The only difference between your MAIN TXE CLEAN.bin and BRASWELL CLEAN TXE.BIN is in the flash descriptor , i did a file compare using HxD .The TXE area is the same. The only thing i probably did differently to you was to choose braswell,not cherry trail in the FIT drop down box.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Thanks smdflea. Will try and update about results.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Unfortunately, it didnt work too-ended up in no display. I again tried lenovo official bios and i get display stuck at lenovo logo that too after 2-3minutes. I have removed lan,audio,card reader chips. Couldnt replace processor and ram as both are soldered. Mb is perfectly clean with no corrosion, no liquid spill. I even tried a mild reflow with no improvement.
            Looking at the dead end????
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              check which signal gets active late. In this way, you may find a clue to discover the faulty component.
                • 20318
                I posted the wrong bios at post #4 ,made a mistake with the model number. Heres another one to try,official bios with latest TXE v2.0.5.3117
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Thanks for your effort smdflea but customer was in a hurry and took away the laptop.
                  PS: Caspian , i did tried that way but couldnt arrive at any conclusion(With my limited knowledge) as lot of voltages change when there is display.
                  • Kevin12111
                    • Mar 2019
                    • 10
                    • Indonesia
                    well , i found same problem here, whats wrong with this type
                    • smali
                      • Sep 2014
                      • 287
                      • Pakistan
                      Hi masters... i have 2 laptops of lenovo ideapad 300s, both of them are looking fresh... but keyboards of both laptops not working... and i bought another lenovo ideapad 120s with brocken screen.. i replaced the screen and its keyboard also not working... so all of three k. b not working even in bios setup that i may install new windows... yes it works on external k. b and mouse... i am really confused what to do... please help
                        • 20318
                        This is the bios requests section,if you want more help start a new thread in the main laptop forum
                        • yahya85
                          • Jan 2021
                          • 17
                          • surabaya
                          hi smdflea can you help me, i need bios lenovo ideapad 300s-11ibr
                          this my old bios
                          case no display
                          • peste
                            • Dec 2016
                            • 12262
                            • ROMANIA
                            this my old bios
                            case no display
                            bios extracted from Lenovo site update..
                            • Nagyesz
                              Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                              by Nagyesz
                              I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                              All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                              How can I extend its lifespan? Could reflow help?
                              It has ryzen 5 5500h, rtx 2050, no soldered ram.
                              Example of the artifacts:
                              03-01-2025, 11:11 AM
                              Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 05:20 AM
                              Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                              Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 05:00 AM
