Need bios dump ACER Aspire One AO1-431 (charging problem)
  • bumper1
    • Jul 2014
    • 72
    • Poland
    I'm looking for dump
    INVENTEC CALTECH 6050A2767601-MB- A01
    There is MX25U6435F, working on 1.8V; My EZP2010 with "1.8V adapter" doesn't recognize it correctly. I wonder if I can use Winbond 25Q64FWSAQ (also 1.8V) with new dump? This one works fine with programmer.
    Laptop is working but has problem with charging ( 2 oryginal chargers, 4 baterries). I replaced charger chip - same thing. I want to try bios.
    • 20276
    Re: Need bios dump ACER Aspire One AO1-431 (charging problem)
    Try this one .
    • Francisco.s
      • 691
      • Spain
      Check voltage (pulses) in EC_SMB1_CLK and EC_SMB_DATA.
      If no voltage on both signals, check readings in diode mode.
      • bumper1
        • Jul 2014
        • 72
        • Poland
        Thanks SMDFlea. This dump works, windows is working, but for my laptop still no charging.
        Both signals are about 3.2V. I don't have oscilloscope.
          • 20276
          upload the schematic if you have it please.
          • bumper1
            • Jul 2014
            • 72
            • Poland
            I did some measure on BQ24725 pins:
            3: 19,2V
            4: 25,0V
            8: 3,2V
            9: 3,2V
            11: 2,4V
            12: 2,3V
            13: 2,4V
            15: 0V (???)
            16: 5,9V
            17: 5,8V
            18: 2,4V
            CN6050 with battery (I have 4 used batteries-all the same):
            pin 1-2: when I plug power supply - it's 2,55V about 5 seconds, jumps to 12,5V; stays 7s and go back to 2,55V and stays like that (4 batteries -same thing)
            3: ground
            4: 3,2V
            5: 3,35V
            6: 3,35V
            7: 0,13V (na każdej baterii)
            8-9: ground
            I refreshed soldering on charger pins and elements around it- didn't help.
              • 20276
              Check if C6050 and Q6012 gets hot when you plug the charger in, test voltage on pin 4 Q6012 when you plug the charger in , for 15 seconds
              • Stevie2001
                • Apr 2018
                • 183
                • irland
                test
                U6600
                U6000
                and all the mofsets near it
                • smali
                  • Sep 2014
                  • 287
                  • Pakistan
                  check Q6010 or Q6011 may be short...
                    • 20276
                    Originally posted by Stevie2001
                    test
                    U6600
                    U6000
                    U6600 has nothing to do with the charging circuit.
                    • bumper1
                      • Jul 2014
                      • 72
                      • Poland
                      Nothing is hot (after few minutes charger + battery). Q6012 Pin 4 (gate): 2,55V about 5 seconds, jumps to 12,5V; stays 7s and go back to 2,55V and stays - exacly like pins 1-2 in CN6050.
                      check Q6010 or Q6011 may be short... - they looks ok
                      U6600 should be ok becouse windows is running.
                      I already changed U6000 (charger) to another (used one- mayby i find another)
                      I also think about replace q6000 AON7934 but is hard to buy. I wonder what replacement I can use.
                        • 20276
                        Can you test these resistors, R6053 (220K) , R6052 (33) , R6050 (33) , R6051 (1K) , R6055 (10K) .
                        • Stevie2001
                          • Apr 2018
                          • 183
                          • irland
                          with normal charger nothing will get hot and if it did it will blow up.
                          Charger has protection you know that otherwise if anything was shorted inside laptop then charger will still inject current
                          • jatoi
                            • Jan 2015
                            • 82
                            • pakistan
                            Try this one .
                            thanks
                            • red1980
                              • algeria
                              good luck
                                ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-12-2024, 03:28 PM
                                ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-12-2024, 02:30 PM
                                ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
