Originally posted by fragga
View Post
Mac air a1466-820-00165-a-lock
Re: A1466 bios passWORD help
Originally posted by kevingill View PostDid you erase flash, write and then verify the new ROM file?
You may also need to do a option-cmd-p-r three boots to clear any previous settings.
Re: Mac air a1466-820-00165-a-lock
Originally posted by odexh View PostThanks peste it works but keeps asking me for a pin code when i try internet recovery
3.2. Apple -> 3.2.2. 2012 to 2017
For 2012 to 2017 machines, BIOS must be edited and reflashed to clear the password. There are 2 methods for this:
Clear out the whole SVS store. There are other stuff in this store, no idea what they are for so better avoid doing this.
Invalidate the CBF2CC32 NVRAM variable in that SVS store which contains the encrypted password. You just have to change one bit in its name, so like replace the C with an A or whatever. Note that strings are UCS-2 encoded, so in the hex editor it'll show up as 0x43 0x00 0x42 0x00 0x46 0x00 etc.
If there is an iCloud pin, you need to perform 3x PRAM reset after removing password. If FindMyMac is still enabled, you have to reinstall macOS while being disconnected from the Internet, then reconnect after logging in and bind to a new Apple account.
Originally posted by odexh View PostCan anyone please help me remove this password??Attached Files
Originally posted by odexh View PostHi guys need help removing password from thisAttached Files
Originally posted by fragga View PostAlso same file , I think my programmer corrupted this dump first time I read it, the Mac only turns fan now , no display, even with the first file , is there any way to fix the dump? No display but fan is running
Originally posted by kevingill View PostI've removed the password from the bin file.
Let us know if this works.
Originally posted by fragga View PostBoard
820-00165-aAttached Files
Board
Originally posted by SMDFlea View PostFind one with clean ME firmware, use the forum search https://www.badcaps.net/forum/showth...A1466+EMC+2925 .You will need to edit in your own serial number thats on the case, and correct the fsys checksum ,see the video linked here
https://www.badcaps.net/forum/showpo...43&postcount=5
4.3. Apple
I just found one, it was a tricky one. Yes i searched for these two terms, but 6 bios was wrong for this air, that was the time i wrote that post. In the end i just found one (Maybe from another site, i downloaded about 20efiwith emc2925 mark.). Idk what was wrong with the other cleaned efis.
Originally posted by Sajtisajti View PostHey guys! Is there someone who has A1466 EMC 2925 1.6GHz 8GB working clean bios? Sadly the original is useless, damaged. Corrosion on efi connector...
Thanks!
4.3. Apple
Thanks!
very thankful for zakeric,CammyTier1 for quick reply , iam very glad to join this group, thanks you hope to learn a lot from you guys
@ hoaca388
thanks man, hope you can teach how to for bios of mac, very thankful for this
test and it work, directly change the ssd with new os, very thankful
