Acer e5-473 no display - BIOS REQUEST
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Re: Acer e5-473 no display
    what could the problem with this one if laptop stays off for a couple of hours and then when i pressed power button turns on and display comes, but when i shut it down and turns on again no display and fan at full speed
    • String2016
      • Nov 2015
      • 2242
      • philippines
      anyone please help on this
      • JaroTech
        • Mar 2015
        • 351
        I have already asked you what voltages are missing?
        • String2016
          • Nov 2015
          • 2242
          • philippines
          i dont know where to check because in the schematic i have there is no PL1202,1203 and pu1201
          • JaroTech
            • Mar 2015
            • 351
            On page 5, you have all the important voltages. PU1201 and all components for the VGA@ are not on the motherboard because you don't have the Nvidia GPU.
            • String2016
              • Nov 2015
              • 2242
              • philippines
              #26
              thanks for the response jarotech for the pu801 all votages is ok but for pu601 pin1 0v pin2 4.4v pin 345 have 19v and pin 17 has 0v
              • JaroTech
                • Mar 2015
                • 351
                When you measure the voltages, you have to press the power button and then read the voltages, for the PU601 chip, the pins 2,3,4,5 are connected together, you have 4,4V on pin 2? Measure all the pins.
                • String2016
                  • Nov 2015
                  • 2242
                  • philippines
                  #28
                  i measured with power button press i checked it again sori my mistake pin2 is also 19v
                  • mcoytzhi27
                    Mr
                    • Nov 2015
                    • 43
                    • philippines
                    #29
                    guys.. the common issue of this model is the hash well itself.. the CPU
                    just replace the new chip and it will fix the issue.. i tried many time
                    • grefaldia
                      • Jul 2020
                      • 21
                      • philippines
                      #30
                      i have same model this as same problim.
                        • 22285
                        If you`re not requesting a bios please start a new thread here:
                        https://www.badcaps.net/forum/forumdisplay.php?f=23 .Post tests done so far with all voltages.
                        • qonma
                          Kuli Solder
                          • Jun 2017
                          • 185
                          • INDONESIA
                          #32
                          Re: Acer e5-473 no display - BIOS REQUEST
                          can clear the password
                          thanks admin
                          • hardware1
                            • Sep 2021
                            • 2949
                            • N/A
                            #33
                            thanks admin
                            Try those Passwords:
                            First Password: 42780060
                            Second Password: 12345
                            all donations are welcome,
                            • qonma
                              Kuli Solder
                              • Jun 2017
                              • 185
                              • INDONESIA
                              #34
                              thanks brother
