Remove_SMM... UEFI.
Re: Remove_SMM... UEFI.
Do you mean about dip switch before power on, or something else instructions?Comment
*Remove all batteries (main battery and RTC battery).
*Patch the bios and make sure to verify it so there aren't any errors when writing.
*Hold down the small switch on motherboard
*Connect charger (laptop should start automatically)
*Wait. It might even take minutes and laptop will beep/restart a few times.
Attached ThumbnailsComment
Not working, I do everything by instructions, but the same thing.*Remove all batteries (main battery and RTC battery).
If still same issue try this file and follow instructions above*Remove all batteries (main battery and RTC battery).
Attached ThumbnailsAttached FilesComment
Are you sure that nobody change the BIOS chip?
See post:
@CraterM
@dani981
I figure it out. The notebook it have 8MB flash. Probably someone try to unlock and replace the chip. Very strange that it start and ask for password. I discovered only when I change the chip
So, I resolved by changing the BIOS chip, write one ME clean BIOS dump. After that I patch the new BIOS.
Thanks for your efforts.Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
by nikola386Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
- Repair ticket management — Track repairs with device details, status, priority, and notes
- Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
- Customer management — Database with contact info and repair history
- Inventory tracking — Manage parts and components
- Business analytics — Real-time stats, financial overview, profit margins, and trend charts
- Professional
Channel: Announcements & Related News
Today, 02:52 PM -
by GuiTiHey everyone!
I need help with my Lenovo Chromebook 100e Gen 3.
Here are the details:- Motherboard: LA-L131P
- MFG Date: 2022/01/07
- MTM: 82J80001BR
- MO: MPNXB2103001
- Factory ID: LI123
I bought a new Winbond 25Q128FVSG chip.
The chip currently on the board is the same model but with different ending letters.
I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
The Chromebook is Google account locked, and I’ve already tried everything.
I understand that I need to replace or...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by m3vuvIts a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
07-15-2024, 10:15 AM -
by CronaxFDHey guys,
Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
From what I've... - Loading...
