HP Elitebook 840 G2
  • Tjaytony
    • Oct 2020
    • 114
    • Nigeria
    #161
    Re: HP Elitebook 840 G2
    Originally posted by Tjaytony
    Hello guys, i have an hp 840 g2 that a customer brought in. it wont detect usb connection. i have troubleshooted the components relating to the usb. everything seems fine. now i realized that it initially detects usb connection then after the cmos reset reboot, it wont detect usb connection anymore.
    so i decided to bring the case here, may be its bios error. here is my main and ec dump below.
    following up on this, one of the dumps posted here worked and usb connection is workinf fine now. but its showing machine not in commited state, and it takes several seconds to boot up. could anyone work on my own bios main dump/backup.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12333
      #162
      What is your serial number? The original file you posted is from the HP EliteBook 850 G2 Notebook PC (ENERGY STAR) with serial number: 5CG5400FK2.
      • Tjaytony
        • Oct 2020
        • 114
        • Nigeria
        #163
        thats a terrible mistake on my end. yes its 850 g2. serial number is 5CG5400FK2
        • Tjaytony
          • Oct 2020
          • 114
          • Nigeria
          #164
          I will check 850 g2 forum maybe i could find a dump there. or if you could help fix my own bios dump
          • hoaca388
            Badcaps
            • Jan 2022
            • 12333
            #165
            Here
            https://www.badcaps.net/forum/showpo...38&postcount=5
            • toha-1
              • Feb 2023
              • germany
              #166
              Hello!
              Have in hands abandoned:
              elitebook 840 g2
              sn 5cg6266w84
              pcid a3009d510303
              bios with password
              tried to reset it with hp_unlock tool and rcunlocker - w/o result. lap turns on after battery attached and blinks
              chip was desoldered from m/b and read twice, dump attached. Read with ch431 clamp (desoldered, don't have nest for it) with settings 26/26 spi flash, winbond, w25q128fv (same written on bios)
              https://drive.google.com/file/d/1JNM...ew?usp=sharing
              https://drive.google.com/file/d/1g-i...ew?usp=sharing
              • peste
                • 13630
                • ROMANIA
                #167
                Originally posted by toha-1
                Hello!
                elitebook 840 g2
                sn 5cg6266w84
                pcid a3009d510303
                bios with password
                post the original bios here not on another site..
                • toha-1
                  • Feb 2023
                  • germany
                  #168
                  ok but when i am trying to upload it doesn't works
                  • wolf3d.exe
                    • Jan 2023
                    • 33
                    Trying to unlock a BIOS but made a quite a mess here,
                    First of all I did not disconnected my cmos battery while dumping, dumped files are attached. Also while I was trying to figure it out probably erased the small chip. Now if I want to reprogram it (desoldered) it says verification error. Picture 1 (small chip, 2mb)
                    If I use latest AsProgrammer 2.0 as stated in this thread for the 16mb chip and when I try to program it with my HPUnlocker unlocked or some of the unlocked roms in this thread, I noticed erasing goes VERY fast. But write verify takes time. And flash succeeds. Picture 2 (16mb chip)
                    So I have both chips desoldered, I have dumps for two. When I put them back on laptop laptop goes into rebooting loop. No display.
                    Obviously something wrong here, why I cannot reprogram the small chip with the original dump?
                    And why I have a problem of with the 16mb chip?
                    • wolf3d.exe
                      • Jan 2023
                      • 33
                      My problem is solved. Issue was the lazy soldering job. Also I will attach the image that worked for me. After reprogramming chip log in to bios as a guest user, surprisingly create an admin account, login to that account and delete existing accounts. Also remove the password for the admin. Voila!
                      Thanks for the original poster for the BIOS also I used Colibri as programmer. Thanks again for the poster of Colibri. It worked without any errors. I will attach that too.
                      • kreatywny
                        • Feb 2023
                        • Poland
                        #171
                        Hello.
                        I have trouble after trying to remove my password.
                        I didn't check the original file with the bios save...
                        And now I have bios with FF's
                        After all I've got caps & num lock blinks, fan rotates at full speed & the screen is black.
                        I've tried bios from #153 - it's the same.
                        Can someone give me a hint what do now?
                        Patient:
                        HP 840 G2
                        BIOS: Winbond 25Q128FVSQ
                        I was using Neoprogrammer 2.2.0.10 & CH341A 1.4
                        • peste
                          • 13630
                          • ROMANIA
                          #172
                          Originally posted by kreatywny
                          Hello.
                          Patient:
                          HP 840 G2
                          Look for a bios on the site according to the motherboard pattern and try it ...
                          • kreatywny
                            • Feb 2023
                            • Poland
                            #173
                            Thanks for response. I've got another small question, maybe stupid, but I'm a little confused.
                            Everybody write about motherboard model with 605...-MB-A02 etc. But on sticker on motherboard I've got only CT: PEVE... + sticker on heatpipe (604... ver: a03) + sticker under battery (607... ver: a02) + under SSD (another 607).
                            I'm guessing there's another sticker, I need to take the case apart to get into it or I'm blind?
                            • peste
                              • 13630
                              • ROMANIA
                              #174
                              the model of the base plate should be written in white paint on one of the parts of the base plate...it has this shape
                              6050a2637901-mb-a02
                              • electrofrankenstein
                                • Apr 2023
                                Hi all! I'm trying to flash a modified BIOS. The flash itself succeeds, but when I install the chip in the motherboard and turn on the laptop, the bios (or some service) runs an automatic recovery tool due to "bios corrupt" or the checksum is wrong. As a result, I have an old bios.
                                1) Can anyone help me avoid or disable the automatic recovery?
                                2) I suspect I need to flash the second chip on the motherboard as well, the one 2Mb
                                But how to create and write the right checksum?
                                HP Elitebook 840 G2 i7-5600
                                System board: PEVDT00WB9C00G
                                BIOS M71 v. 01.31
                                  • Apr 2023
                                  So, as far as I understand, you ended up flashing both chips?
                                  • peste
                                    • 13630
                                    • ROMANIA
                                    #177
                                    post the original bios, which programmer do you use? how do you know that the bios is the problem?
                                    • Concord2022
                                      • Aug 2022
                                      • 17
                                      • nigeria
                                      #178
                                      This works, but shows machine not in committed state
                                      • mberbouch
                                        • May 2014
                                        • 109
                                        • Morocco
                                        #179
                                        Re: HP EliteBook 840 G2 clear password
                                        Originally posted by Pasha_Lu
                                        Try.
                                        Thanks its working.
                                        • Paul.Junge2020
                                          • Feb 2023
                                          • 39
                                          • Ukraine
                                          #180
                                          Hello. Help is needed. There is HP 80 g2. I'm trying to remove the bios password through the programs - HPUnlocker, RCUnlocker_v_1_0.
                                          But I'm getting flashing white and red light.
                                          Help me please.
                                            HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:50 AM
                                            HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:20 AM
