HP ProBook 650 G2 6050a2723701-mb-a02
    Re: HP 650 G2 6050a2723701-mb-A01
    Originally posted by peste View Post
    try..
    Thank you so much, it works !
    Is this a new dump or did you repair the one i uploaded? if so can you share the
    process to fix it.
    Anyway, thanks again.
      process to fix it.
      is the one posted by you repaired ..
      https://www.badcaps.net/forum/showthread.php?t=88533
        please can you help me? it have password at start tried others but i dont have image
          try..
            Re: HP ProBook 650 G2 6050a2723701-mb-a02
            Got one here with bios password.
            thanks...
              thanks...
              Try:
              Become a Badcaps supporter
              Thanks to all supporters.​
                Originally posted by Vesko356 View Post
                Try:
                it works. thank you very much
                  Re: bios hp probook 650 g2
                  here u go
                  this is ok and tested
                    Hi, I have this laptop, didnt start at all, after I flash bios it starts now but no display and fan work at 100% I tried loads of bios bin fie non of them work correctly, any ideas. I dont have original bios only this ( starts but no display)
                      There are 2 different bios for the 640 g2 (also the 650 G2) , N76 and N87
                      Try both as we don`t know what version you originally had .
                      https://www.badcaps.net/forum/showpo...00&postcount=7
                        thank u so much it works !!!! its working first one made a job now can someone explain me one thing I had those bin before but I didnt desolder chip from board befor programmed, this time I desoldered chip programmed and it works. My question is is it coincidence or shoud I desolder chip before programming every time. an SMDFlea u made my day !!!
                          As a rule, bios chip should be programmed out of the board, the chances of having all kind of problems are quite high if you do it in a circuit.
                            ok tahnks for info. thread to close
                            Per aspera at astra !
                              Hmm,so many questions about bios programming, you know what we need
                                Yeah, I know
                                Writing such a guide is clearly necessary. I see people here every day who get themselves into a big trouble because they don't follow basic rules. I won't be able to start until the end of the week (I'm too busy at work), but next week I'm sitting down to write it.
                                  CIRCUS-6050A2723701-MB-A02 bios
                                  hi please i need bios hp probook 640 g2
                                  mainboard : CIRCUS-6050A2723701-MB-A02
                                  THE LAPTOP WORKS WITH THIS DUMP BUT IT GOES VERY SLOW SSD NEW NEW RAM BUT IT GOES SLOW SO I WANT TO TRY ANOTHER DUMP TO SEE IF THAT IS SOLVED TAKNK YOU
                                  THIS IS MY BACKUP
                                  i have tried to download it from the hp official page but I get 9.216kb and mine is 16.384kb
                                    Re: CIRCUS-6050A2723701-MB-A02 bios
                                    THIS IS MY BACKUP
                                    The 9.216kb is a 9MB update, not the full bios. If its only running slow try cleaning the ME region. ME cleaning guide https://www.badcaps.net/forum/showthread.php?t=88533
                                      thank you smdflea for your reply after cleaning me region now i have no image i did it with MEinject.exe
                                        MEInject isn`t recommended for anything above version 6/7 FW. Use the win-raid guide.Give it a go,if you can`t do it let us know .
                                          ok thanks for the info i used the win-raid guide but still the same no image
