HP ProBook 645 G1 Bios dump
  • cvorke
    • Oct 2012
    • 26
    • Solar system
    Can somebody share dump for HP 645 G1
    Or instruct me how to edit BIOS file from HP site. I downloaded bios but it is empty with serial, model etc... and when I turn on laptop it always says that following data is missing.
    So I have my old bios dump (locked) and new from HP site without those data.
    Eprom dump will solve my problem because serial no is not important to me but knowing how to edit HP bios will be much more useful.
    Thank you!
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: HP ProBook 645 G1 Bios dump
    send old bios.
    • cvorke
      • Oct 2012
      • 26
      • Solar system
      Old bios attached.
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Try this and reply.
        • cvorke
          • Oct 2012
          • 26
          • Solar system
          Works perfectly, thanks!
          • Pascal Komlassan
            • Jan 2017
            • 809
            • TOGO
            Originally posted by imranromi
            Try this and reply.
            thank's bro
            • casablanca
              • Aug 2016
              • 7
              • South Africa
              hi friend the file works 1000000%%%%
              thanks alot
              • mohamedinalex2000
                • Jun 2018
                • egypt
                can I have file smc.bin of HP probook 645 G1
                uuid: BFE4D8B0026FE8119D9D2FC85F0680B9
                S/N: CNU417CTDD
                • slashzakk
                  Daniel
                  • May 2018
                  • 13
                  • Argentina
                  Hi, Can somebody share dump for HP 645 G3?
                    • 21679
                    The full 16MB bios is available from hp. Extract the files with 7zip or winrar,or run the exe it will give you the option to save the bios .
                    https://ftp.hp.com/pub/softpaq/sp870...00/sp87045.exe
                    • slashzakk
                      Daniel
                      • May 2018
                      • 13
                      • Argentina
                      cool, thanks, this is the only i cand do? i descompressed the file with winrar...
                      in the list of archives the bios is the .BIN no?
                        • 21679
                        Yes,the .BIN is the bios file.
                        • slashzakk
                          Daniel
                          • May 2018
                          • 13
                          • Argentina
                          thank you very much, later I try it and I tell you
                          • slashzakk
                            Daniel
                            • May 2018
                            • 13
                            • Argentina
                            Hi SMDFLea, this works perfectly ! thank you, grettings from argentina.
                            • jhuztine2881
                              • 37
                              • Philippines
                              Thanks works perfect!!
                              • Cocaveto
                                • Mar 2019
                                • Egypt
                                Hello
                                How to use the file I wiped all the data on the Fat32 USB flash drive and moved the file to it and the device does not enter it nothing after pressing the Start button and the top and bottom arrow button and the power button does not enter the file nothing happens
                                What do I do
                                I use Linux
                                apologize for the language problems
                                • arslansharif
                                  • Oct 2016
                                  • 45
                                  • pakistan
                                  thanks
                                  • montier
                                    • May 2016
                                    • singapore
                                    Try this and reply.
                                    may GOD always bless you sir, thank you very much
                                    although this post has been 2 years ages
                                    you help me solved my problem
                                    • hamada2h
                                      • Nov 2018
                                      • 7
                                      • egypt
                                      Originally posted by cvorke
                                      Old bios attached.
                                      thanx bro but password bios ?? !!!!
                                      • peste
                                        • 13420
                                        • ROMANIA
                                        use the next post...#4
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • greelidd
                                          K6604J Vivobook RTX 4070 BIOS Dump Request
                                          by greelidd
                                          Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                                          Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                                          09-01-2025, 06:14 PM
                                        • solomost
                                          need bios dump for HP ProBook 640 G2
                                          by solomost
                                          HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                          prblm: black screen caps lock blinking 5 times then fan spening
                                          CT: PFKCT00WB69310 REV : 1.20
                                          motherboard : HSB J Mv-6 94v-0 E89382
                                          03-21-2025, 06:22 AM
                                        • ktcar214
                                          Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                          by ktcar214
                                          Hello.
                                          I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                          My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                          I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                          12-07-2021, 08:57 AM
