clevo w650sj bios
  • charley91
    • Nov 2014
    • 11
    • united kingdom
    clevo w650sj bios
    I have an i7 Clevo W650SJ powers on ok after a couple of minutes it beeps and three led's start blinking and CPU fan speeds up then laptop cuts off
    any help would be much appreciated
    Thanks in Advance
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: clevo w650sj
    assuming all main voltages are present at coil's side , you may try programming bios at first
    • charley91
      • Nov 2014
      • 11
      • united kingdom
      Re: clevo w650sj
      Thank you for information I will have a look at it later
      • charley91
        • Nov 2014
        • 11
        • united kingdom
        Re: clevo w650sj
        I have been trying to get an update bios for it and no joy
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          Re: clevo w650sj
          Originally posted by charley91
          i have been trying to get an update bios for it and no joy
          try
          • charley91
            • Nov 2014
            • 11
            • united kingdom
            Re: clevo w650sj
            Didn't work thanks all the same for trying to help resolve problem
            • giove
              • 26
              • Italy
              Re: clevo w650sj
              hi i have the same problem, have you resolve?
              • nurhan
                • Jan 2015
                • 27
                • Turkey
                Re: clevo w650sj
                I had same problem. I wrote EC and problem solved. I hope it helps somebody.
                • BILLYSRIZARI
                  • Sep 2014
                  • GREECE
                  Re: clevo w650sh
                  I have an i7 Clevo W650SH powers on ok after a couple of minutes it beeps and three led's start blinking and CPU fan speeds up then laptop cuts off
                  any help would be much appreciated!!
                  • qonma
                    Kuli Solder
                    • Jun 2017
                    • 185
                    • INDONESIA
                    Re: clevo w650sh
                    same problem
                    • Sojke
                      • Apr 2017
                      • 131
                      • Serbia
                      Re: clevo w650sj
                      Originally posted by dycc
                      try
                      Thank you, works.
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • cr4zychriss
                        by cr4zychriss
                        • Rebrand: PC Specialist
                        11-14-2025, 04:04 PM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • Axton
                        Bios for Clevo P670RP6
                        by Axton
                        My laptop has a GTX 1060 installed, but it is not recognized in the BIOS (see attachment). The chip gets warm and the fans spin. I think there is an error in the BIOS.
                        Could there be a switch to activate/deactivate the graphics card?
                        I am also unable to install an Nvidia driver in Windows.
                        Data about my motherboard:
                        S/N: 1TP670RP6310404
                        P/N: 6-77-P670RP6A-N02A-B#10​
                        If anything else is needed, just let me know.​...
                        09-15-2025, 10:28 AM
