MacBook Air A1465 820-3435-B
  • madstan
    • Jun 2017
    • 3
    • Philippines
    #101
    Re: MacBook Air A1465 820-3435-B
    Originally posted by edwinmau06
    Try this, I managed to make a backup of a good team. I hope it can work for you.
    Confirm if this option works for you.
    thankyou will try it
    • lordmuken
      • May 2018
      • 57
      • Philippines
      #102
      MacBook Air 11" A1465
      My unit is MacBook Air A1465 11inch
      Board model: 820-3435-B
      Can only one help me with fixing my bios?
      My concern is efi lock, i try editing the $SVS with hex editor to remove my efi lock. after the chime and i press and hold the cmd+opt+r+p then, nothing happened.
      i think my problem is my built-in keyboard.
      Then i use my USB external keyboard and press + hold those combination keys again before the chime. still nothing happen.
      when i press the option key, the padlock is still active.
      • kevingill
        • Jun 2013
        • 152
        • England
        #103
        Re: MacBook Air 11" A1465
        That bin file doesn't look right. You should wipe everything between the $SVS markers.
        Also do option-command-p-r to chime three times.
          • 22216
          Please read the Rules, next time you should look for a related thread to post in instead of starting a new one
          • lordmuken
            • May 2018
            • 57
            • Philippines
            #105
            sorry about that.
            • lordmuken
              • May 2018
              • 57
              • Philippines
              #106
              yes i know, i already Fill the highlighted section in the $SVS with the F. and the problem still persist. i bought this unit the fb market as defective, no power and signs of liquid damage in the BIOS side.
              after fixing the traces in the logicboard, the unit chimes and power on but have EFI lock. Is it possible for the external keyboard will not work when doing SMC reset? or there is a problem in the BIOS?
              • peste
                • Dec 2016
                • 13880
                • ROMANIA
                #107
                try..
                • lordmuken
                  • May 2018
                  • 57
                  • Philippines
                  #108
                  Originally posted by peste
                  try..
                  Thank you sir! my unit is now working
                  • adiljan
                    • May 2019
                    • 4
                    • New Zealand
                    #109
                    hi there anyone provide 820-3435-B EMC 2631 BIOS BIN CLEAN FILE PLEASE
                    • sizar00740
                      • Jun 2022
                      • 13
                      • ALGERIA
                      #110
                      Please i need to clean my efi
                      • peste
                        • Dec 2016
                        • 13880
                        • ROMANIA
                        #111
                        try..
                        • sizar00740
                          • Jun 2022
                          • 13
                          • ALGERIA
                          #112
                          try..
                          thank you very match bro
                          • robsonrj01
                            • Jun 2021
                            • 14
                            • zcz
                            #113
                            please clean-me bios for MacBook Air A1465 820-3435-B
                            • sysaputra
                              • Feb 2021
                              • 10
                              • Indonesia
                              #114
                              try this one
                              • robsonrj01
                                • Jun 2021
                                • 14
                                • zcz
                                #115
                                Originally posted by sysaputra
                                try this one
                                did not work friend continues firmware and login
                                • robsonrj01
                                  • Jun 2021
                                  • 14
                                  • zcz
                                  #116
                                  please need clear me bios password file for my backup
                                  • peste
                                    • Dec 2016
                                    • 13880
                                    • ROMANIA
                                    #117
                                    reset PRAM...
                                    • robsonrj01
                                      • Jun 2021
                                      • 14
                                      • zcz
                                      #118
                                      reset PRAM...
                                      thanks friend it worked 100%
                                      • elbtonet
                                        • Nov 2019
                                        • 106
                                        • albania
                                        #119
                                        Hi Friend need to remove my efi pass for my macbook
                                        A1465 EMC2924
                                        sn C02PC0NEGFWP
                                        • Vesko356
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #120
                                          A1465 EMC2924
                                          sn C02PC0NEGFWP
                                          Unlocked:
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
