ACER Aspire 5733 LA-6582P
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Hi friends,
    Does anyone have schematic & boardview for ACER Aspire 5733 LA-6582P mainboard ?. I need Bios Dump also( EC+ Main ).
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: ACER Aspire 5733 LA-6582P
    I am having a problem on this Board its old bios file is 1024kb size. But i download from some site that file is 4096kb. now i am confusing on these bios dump. what is the actual size. i found the chip size is 8mb. but when i flash it with 4 mb file it show successfully flashed message also. but when i read that flashed file it shows only 1mb file.
    ACER Aspire 5733 ( PEW71 )
    LA-6582P
    Bios chip : MX 25L8005M2C
    • peste
      • Dec 2016
      • 12868
      • ROMANIA
      LA-6582P
      try this
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Dear raaj kumar, I'm uploading acer 5742 main bios and its same as acer 5733.
        Main bios is 4mb. Moreover my bios with clr me and 100% tested ok.
        You should try with w25q32bv or similar chip.
        Good luck
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          Ok. i will do it and i will update the results.
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Its not showing anything on screen and it also show i 1mb bios dump after i flashed. i used on w25q32bv chip it shows 4mb flashed file. but the laptop going shutdown after few seconds and it also not showing anything on screen.
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              ASPIRE 5733-564G50Mnkk DUAL CORE
              MODEL ; PEW71
              • ridamouh159
                • Nov 2014
                • 365
                • maroc
                ASPIRE 5733-373G32Mlkk CORE I3 SALIMA
                • ridamouh159
                  • Nov 2014
                  • 365
                  • maroc
                  ASPIRE 5733-564G50Mnkk CORE I5
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    Thanks ridamouh159 for your information. So i think this laptop already opened by any technician and changed that U18 by MX 25L8005M2C. so this chip is not compatible for this board. i will try with your bios dump again with Winbond 25Q32bv chip and inform you.
                    • raajkumar
                      • Mar 2015
                      • 354
                      • Srilanka
                      Yes ridamouth156 you are correct That bios chip must be 25Q32bv someone has changed by MX25l8005, they changed the PU12 also by improper chip. I think they were planned this laptop has thrown to garbage. Now its working with your bios dump with 25Q32bv chip. Display also working. Thank you again. You did a big help to me.
                      • raajkumar
                        • Mar 2015
                        • 354
                        • Srilanka
                        Thanks everyone who helps to solve this problem.
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          Hi I am having a problem on this same board. 19V input connector shows 19V ok. On PL42 it show power fluctuation. its going down from 19V to 16V, 13V, 10V, 9V. I found a cap PC1011 is short circuited and i replaced it. but the problem still. I replaced PU17, PU1000 also but problem not solved. anyone having any idea ?
                          • nafienew
                            • Aug 2014
                            • 92
                            • maroc
                            Thanks ridamouh159
                            • charafmak77
                              • Oct 2017
                              • 81
                              • jijel
                              I need pew71 la-6582p rev 1.0 BIOS
                              • elfenne
                                • Mar 2016
                                • 46
                                • maroc
                                thank you
                                • lucasbronney
                                  • Apr 2019
                                  • brasil
                                  Bios of acer aspire 5742 is compatible with acer aspire 5733, as both have the same motherboard numbering, PEW71 LA-6582p?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    yes, its compatible. You may,however, face shutdown in 10-15 mins issue when swapping bios between these 2 boards and thats "coz of me region.
                                    • nabilgo
                                      • May 2016
                                      • 303
                                      • L.A
                                      thx so much it work perfect and happy ramadan
                                      • bardos
                                        • May 2019
                                        • 4
                                        • usa
                                        is the bios chip at U18 or at U31?
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
