E7450 la-a961p bios
  • kodoxp
    • Apr 2022
    • jakarta
    Re: E7450 la-a961p bios
    clear password please
    • amiralipay
      • Oct 2022
      • 16
      • iran
      Tnxxxxxx
      • sy_sanyo
        • May 2019
        • 9
        • viet nam
        thanks
        • Oleh2605
          • Sep 2020
          • 5
          • Italia
          thank...
          • cravel
            • Nov 2022
            • 27
            • philippines
            help guys for this bios no dispaly
            ZBU10 LA-A961P
            original dump file is attach
            • davidfrank77
              • Sep 2017
              • 21
              I need LA-961p MEC5085 bin file please it's urgent
            • supun1992
              • Jun 2017
              • 13
              • Sri lanka
              #27
              LA-A961p MEC5085 kbc bios plz?
            • champaca
              • Sep 2023
              • 3
              • philippines
              #28
              BIG THANKS YOU TO SIR PESTE,MY LAPTOP WORKS THANK YOU SIR FOR BIN FILE YOU UPLOADED
              • szakacsa195
                • Apr 2022
                • 45
                • Magyarország
                #29
                Please, help to repair attached bios files. (Screen black, fan spins, led lights)
                motherboard:zbu10 la-a961p rev. 1.0
                serial no: not find on board or housing
                service tag: 7XQ3062
                Thanks!
                • szakacsa195
                  • Apr 2022
                  • 45
                  • Magyarország
                  #30
                  Thanks!
                  Can anyone help me, please.
                  Thanks!
                  • kalilinux25
                    • Mar 2018
                    • 2069
                    • ZAMBOANGA SIBUGAY
                    #31
                    Thanks!
                    here give feedbacks always
                    • szakacsa195
                      • Apr 2022
                      • 45
                      • Magyarország
                      #32
                      Thanks!
                      Not working. Same problem as originally. Screen blank, fan spin up, cpu hot, led lights.
                      • kalilinux25
                        • Mar 2018
                        • 2069
                        • ZAMBOANGA SIBUGAY
                        #33
                        Thanks!
                        try this one this is fresh
                        • szakacsa195
                          • Apr 2022
                          • 45
                          • Magyarország
                          #34
                          It is worse.
                          With fresh dump LED does not turn on, and fan does not spin. Only CPU getting hot.
                          • kalilinux25
                            • Mar 2018
                            • 2069
                            • ZAMBOANGA SIBUGAY
                            #35
                            It is worse.
                            maybe you have a diffrenet issue
                            • szakacsa195
                              • Apr 2022
                              • 45
                              • Magyarország
                              #36
                              Could be... however all voltages are ok.
                              Tried another dump with same result.
                              Anyway thank you for your help.
                              • shamaltech
                                • May 2023
                                • 99
                                • Sri Lanka
                                #37
                                try..
                                Can you fix this Bios?
                                When I press the Power button, laptop turn on then suddenly turn off.
                                  • 20504
                                  Service tag ? https://www.badcaps.net/forum/troubl...before-posting
                                  • shamaltech
                                    • May 2023
                                    • 99
                                    • Sri Lanka
                                    #39
                                    Originally posted by SMDFlea
                                    5W6RQN2
                                    • nguyengtung
                                      • Jan 2022
                                      • 5
                                      • Singapore
                                      #40
                                      I need MEC5085 rom in Dell E7450 zbu10 la-a961p. please help me!
                                      service tag: No found, i don't see it
                                      Thanks!​
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • zungu
                                        e7450 la-a963p motherboard add bios option
                                        by zungu
                                        I have a Dell e7450 i7, the one with the msata port only, not the 2.5 sata port which is the i5 version of E7450. I tried to install a ssd in the WWAN port of that E7450, as I did in a 5580 (in that case both sata and pcie worked 2242 B+M key!). NONE of the ssds I have (sata or pcie b+m key 2242) worked in the WWAN port of the E7450 (Bios and Windows). I wonder if it's something locked in the Bios because nothing is visible in the Bios. The Bios suggests that only another sata ssd would be accepted if it's a ssd connected to a dell docking station ("esata dock port"), zero mention in...
                                        06-04-2023, 03:56 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
