Acer aspire es1-512 BIOS Please
  • asliyucegsm
    • Jun 2011
    • 350
    • Turkiye
    #41
    Re: Acer aspire es1-512 BIOS Please
    Thank you
    • fcelikel
      • Jan 2019
      • 13
      • türkiye
      #42
      ok
      • Maruco
        • Jul 2018
        • Brazil
        #43
        Please Firmware (BIOS) Acer ES1-512-C59L Please
        • peste
          • 13430
          • ROMANIA
          #44
          post the original laptop bios
          • tano2060
            • May 2018
            • 28
            • Macedonia
            #45
            Originally posted by cyberhack
            Here you go
            • amamos
              • Jul 2019
              • 13
              • France
              #46
              Thanks!!!
              • ycok
                • May 2017
                • 37
                • Türkiye
                #47
                thank you
                • luiz34
                  • Nov 2016
                  • argentina
                  #48
                  Thanks!! you saved me!!
                  • Abdulkadertabbakh
                    • Feb 2018
                    • 10
                    • syria
                    #49
                    Thanks you
                    • moh17
                      • Feb 2018
                      • 34
                      • Algeria
                      #50
                      thank you
                      • Sami Wahid
                        • Oct 2015
                        • 77
                        • Morocco
                        #51
                        thank you
                        • platinumsteel
                          • May 2019
                          • 234
                          • Trinidad&Tobago
                          #52
                          Acer ES1-512_C1PW bios needed
                          Hi guys I need help.I have no display on this acer labtop .
                          ea53-bm/eg52-bm mb 14222-1 448.03703.0011
                          I will post a copy of my backup original bios here and snid
                          SNID 53401272066
                          Thanks in advance
                          • matusiq
                            • Dec 2020
                            • 58
                            • Slovakia
                            #53
                            Re: Acer ES1-512_C1PW bios needed
                            SNID 53401272066
                            Thanks in advance
                            Your dump is bigger of couple bytes ,, try to save it one more time ... here is another dump to try
                            • platinumsteel
                              • May 2019
                              • 234
                              • Trinidad&Tobago
                              #54
                              Thanks a lot for pointing that out to me.You are right.Well if that is the case that is the only backup i had taken.So chances of getting the original backup will not be possible because i have already erase the chip.I will try that dump you sent and see how it goes. thanks
                              • matusiq
                                • Dec 2020
                                • 58
                                • Slovakia
                                #55
                                Well to be honest bigger is always better even in BIOS dump But it may be some problem with reading ... so always do 2x reading and compare the files ...
                                • platinumsteel
                                  • May 2019
                                  • 234
                                  • Trinidad&Tobago
                                  #56
                                  Okay just flashed the bios you posted and i get picture now.Only thing i notice is I get a critical low battery logo coming up on screen whether i have the labtop battery plugged in or not . And it's not charging the battery apparently. So thanks for the working bios.I will post my other issue in another forum section. Thanks again.
                                  • matusiq
                                    • Dec 2020
                                    • 58
                                    • Slovakia
                                    #57
                                    Well I can try to rebuild your BIOS If the issue is not in BIOS but I doubt that ... it could be charging IC. Not sure ...
                                    Still with the dump that U have now U are going to missed information regarding the model, serial ...etc. ,, U can edited the BIN and find all the information in your dump ...
                                    Offset starting from 0x520003 till 0x520101
                                    I have attached updated info in BIOS dump.
                                    • platinumsteel
                                      • May 2019
                                      • 234
                                      • Trinidad&Tobago
                                      #58
                                      thanks a million my friend.Bios is working 100% fine now.
                                      • matusiq
                                        • Dec 2020
                                        • 58
                                        • Slovakia
                                        #59
                                        Brilliant ... ,, You are more that welcome man.
                                        BTW Empty some messages from Your box ... cant send you msg
                                        • rugal.souza
                                          • Aug 2020
                                          • Brazil
                                          #60
                                          Re: Acer Aspire ES1-512
                                          Originally posted by borbooroski
                                          Acer Aspire ES1-512 EA53-BM EG52-BM MB 14222-1 Bios file needed please......
                                          Try this!
                                          • EbrahimSiami
                                            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                            by EbrahimSiami
                                            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                            **What I have tried so far:**
                                            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                            07-02-2025, 02:31 PM
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
