Hello again. Thank you for your help. I did the bios dump wrong. I learned EC dump and Bios dump. i saw ready bios in forum. I used. it worked but the computer starts up late. fan switches on late. I improved myself in this regard. I will give all the information you want. my original Bios is password protected. can you remove the password Below I am giving the original bios and other information of 8MB size.
the posted bios is empty, remove the bios chip from the motherboard before reading or writing, make a copy and post again.
Yes. empty. I noticed later on. I am sure I did the procedure correctly. I inserted the chip. recognized. chip ID 25B64BSIG. does not do automatic recognition. I am using a Windows operating system. That's why I did research. GD25Q64 was a suitable ID. this way i got the bios dump. I deleted the contents of the chip. i placed another bios i found on forum. causes the computer to start up late. Lenovo post seems a bit late, after it appears it goes away again. is coming again. the computer turns on. the fan starts spinning late. Can you recommend another bios suitable for my computer?
bios extracted from the update on the Lenovo website
I tried it and it works. Fully compatible. I got rid of the bios password. I changed the operating system. I am so happy. This is thanks to you. Thank you very much for your time. Your site is very good, helpful. I want to ask a question on a subject: after all these developments I am having a battery problem. It is not 100% full. It stays at 60%. The charge signal goes back and forth. Is this problem due to hardware or operating system?
