HP Elitebook 820 G2 bios needed
    Re: HP Elitebook 820 G2 bios needed
    Tnx
      Need bios repair hp 820 g2
      board id snickers-6050a2635701-mb-a02 (hstnn-i29c)
      serial 5cg5261109
      prodult h9w31et
        Need bios hp 820 g2
        board id PEVDH00WB9M1Y6
        serial 5CG5431VYG
        prodult F6N30AV
        MERCI
          Originally posted by pourvou3 View Post
          Need bios hp 820 g2
          serial 5CG5431VYG
          prodult F6N30AV
          MERCI
          always when you request a bios, also post the original bios even if it is corrupted
            Ok
              Ok
              HP EliteBook 820 G2 Base Model Notebook PC
              Become a Badcaps supporter
              Thanks to all supporters.
                Thank you so much i will try and inform you
                  Thank you so much
                    HI I have set the bios of the PC BUT the screen remains black and the fan is running at high speed
                        try this one flashing the 128
                        I hope It'll work for you
                          try this one flashing the 128??????
                            you made a backup of 2 different chips in the file you posted
                            only write what I sent you to the main bios chip
                            you named it "BIOSREDOUANE128.bin"
                              OK THANKS MY FRIEND
                                THANK YOU MY FRIEND it works but remains the problem of locked mpm
                                  Just update bios from official HP website to latest version
                                  If problem stays here for you https://youtu.be/9T57ktw8n3Y
                                    OK CHOUKRANE :réjouir:
                                      HP EliteBook 820 G2 BIOS password
                                      Can anyone find out the Bios password from the eeprom W25Q128FV file attached?
                                      My programmer can only read the memory but cannot write the dump.
                                      Thanks.
                                      https://www.badcaps.net/forum/attach...1&d=1666292172
                                        Re: HP EliteBook 820 G2 BIOS password
                                        Thanks.
                                        Impossible.
                                          Please I need 820 g2 unlocked bios bin file
