dell inspiron 11
    dell inspiron 11
    Hellooo friends, I need help.
    Motherboard issue, power and shutdown.
    I want bios dump for dell p20t, Redwood : wfh9r.
    Thank you.
    Re: dell inspiron 11
    I try reflow but same issue.
    I believe that, only BIOS is the problem.
    Thanks.
      hi friend,
      please tell me the symptom to help you
      keyboard led on or off
      ventilator speed or off
      bios appears on or off
        I think the procesor becomes hot
          The netbook powers on for a half a second and shut down.
          I have 5v and 3v ok (for a half a second) and the processor is cold.
          I take measures in bios 3v but for a half a second.
          Nothing else.
            bios pass
              Bios Pass
                U have original dump then plzz send...
                  Just fixed one of these today after liquid damage around PU4503 (3.3/5V regulator). 5V was sitting around 3V or so. Replaced a few caps and the IC itself and ok. Worked for a few minutes then shutdown. Then is in a boot loop of starting and shutting down within a few seconds. There was some extra liquid damage under the daughter board near EC703, might be decoupling for the power switch. Replaced that with a 1nf cap and working.
                  I did take a dump of the BIOS but noted that it had a very old TXE firmware (1.1.0.1089). I was unable to find this anywhere, but I'll post the backup as it is working.
                    Thanks!
