Bios Request-Toshiba Satellite C650D-PSC16A
  • sparker1
    • Sep 2011
    • 343
    Hi, I can only find an "update" .exe bios file for this laptop on the Toshiba website. Grateful if somebody would give me a .bin or .rom file otherwise I'll have to try extracting it and it may only be a partial file. Not to mention I haven't always been successful in extracting them from the .exe files. Anybody help?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Bios Request-Toshiba Satellite C650D-PSC16A
    backup old and try this
    Im Back... sort of...
    • sparker1
      • Sep 2011
      • 343
      Thank you. I'll try it in the morning.
      • sparker1
        • Sep 2011
        • 343
        Ala_Borbe, that bios worked fine. Thank you.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • HOHA
          BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
          by HOHA
          Hi can you help me
          I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
          IP3_TN16S_MB_V30_20210901A
          This is the old BIOS file, it is corrupted​...
          10-20-2024, 08:22 AM
