Acer Helios 500 PH517-51-99UR GPU VBIOS
  • MaksaMax
    • Oct 2025
    • 11
    • Serbia
    MODEL NO: N17Q11
    SN: NHQ3NEG00584218A517600
    SNID: 84210094576
    Pls me vbios gpu 1070, Please tell me which BIOS is for the GPU of this graphics card. The old BIOS takes up 1MB
  • peste
    • Dec 2016
    • 13581
    • ROMANIA
    MODEL NO: N17Q11
    SNID: 84210094576
    post the contents of the bios chip even if it is corrupted..(main, VBIOS)..
    • MaksaMax
      • Oct 2025
      • 11
      • Serbia
      Thank you for your quick response, you deserve donations. I will donate.
      • MaksaMax
        • Oct 2025
        • 11
        • Serbia
        Is anything else needed?
          • 21869
          Wrong chip. That`s the thunderbolt firmware
          • MaksaMax
            • Oct 2025
            • 11
            • Serbia
            You are right, the chip was hidden under the metal part for cooling, so I didn't see it, I apologize, here I am sending the main bios and the vbios from the graphics. It doesn't give me a picture, the keyboard lights up, the fans spin, everything is okay, but no picture.
            I apologize again.
            • piszpunta
              • Jan 2019
              • 255
              • poland
              I apologize again.
              Try
              • MaksaMax
                • Oct 2025
                • 11
                • Serbia
                I think the problem is in the vBIOS
                • MaksaMax
                  • Oct 2025
                  • 11
                  • Serbia
                  piszpunta I inserted it, I tried with this bios, but nothing solved the problem, the problem is still the same.
                  peste
                  SMDFlea​
                  Please, administrators, if you can help me solve this problem, my head started to hurt from thinking.​
                    • 21869
                    The only vBios i could find is the one at Techpowerup and it`s exactly the same as yours.
                    • MaksaMax
                      • Oct 2025
                      • 11
                      • Serbia
                      I've been searching the internet these days for nowhere I've been and I couldn't find anything, absolutely nothing.
                      Can anyone help me here by any chance or do I just have to literally throw away my laptop
                        • 21869
                        Your vBios is exactly the same as this unverified one at Techpowerup https://www.techpowerup.com/vgabios/205083/205083 ,i checked it with a hex editor. If your vBios has never been flashed before then it should be good and the problem is somewhere else.
                        • MaksaMax
                          • Oct 2025
                          • 11
                          • Serbia
                          Maybe the problem is in this main bios, for some reason it doesn't show an image, everything turns on normally but there is no image.
                          • MaksaMax
                            • Oct 2025
                            • 11
                            • Serbia
                            And why is there such a difference between my 1 MB bios and this 233 KB bios you sent?
                            Do I flash that bios to the chip even though it is 233 KB?
                              • 21869
                              The rom file at Techpowerup will have been saved from a running machine using GPU-Z .It only saves the code not the extra padding. If the chip was 2MB it would still only have 233KB ,the rest padded out with FF`s. No ,you don`t want to flash it the code is exactly the same apart from the padding. You can compare both files with a hex editor if you want to, they are identical apart from the padding.
                              I`m pretty sure the vBios is ok and your problem is somewhere else.
                              • MaksaMax
                                • Oct 2025
                                • 11
                                • Serbia
                                I don't know if it's not the main bios, I didn't change it and I didn't find it?
                                • MaksaMax
                                  • Oct 2025
                                  • 11
                                  • Serbia
                                  Can you take a look at the main bios?
                                  • Wg188
                                    ACER Veriton Z4660G AIO bios help
                                    by Wg188
                                    I have an Acer veriton Z4660G all in one pc,
                                    Model: Z4660G-I5850H1 (VZ4660G_W)
                                    Need bios dump and schematic would save my life !
                                    to make a long story short I bought this all in one used
                                    with a broken lcd, with the objective of making a custom desktop out of it
                                    ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                    06-17-2023, 02:20 PM
                                    Acer Predator Helios 16 PH16-71-99ST Notebook Helios 16 Specification for Upgrade or Repair
                                    This specification for the Acer Predator Helios 16 PH16-71-99ST Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Helios 16 PH16-71-99ST boardview and Helios 16 PH16-71-99ST schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 06:38 AM
                                    Acer Predator Helios 18 PH18-71-94P1 Notebook Helios 18 Specification for Upgrade or Repair
                                    This specification for the Acer Predator Helios 18 PH18-71-94P1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Helios 18 PH18-71-94P1 boardview and Helios 18 PH18-71-94P1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    Acer Predator Helios 16 PH16-71-99HU Notebook Helios 16 Specification for Upgrade or Repair
                                    This specification for the Acer Predator Helios 16 PH16-71-99HU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Helios 16 PH16-71-99HU boardview and Helios 16 PH16-71-99HU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    Acer Predator Helios 300 PH315-53 Notebook Helios 300 Specification for Upgrade or Repair
                                    This specification for the Acer Predator Helios 300 PH315-53 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Helios 300 PH315-53 boardview and Helios 300 PH315-53 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 10:20 PM
