MSI GF66 11UC FORGOTTEN PASSWORD
This topic has been answered.
  • lagk0u
    • Oct 2025
    • 7
    • greece
    I recently forgot my bios password for my Msi Gf66 11uc i tried everything even removed the cmos battery i even contacted msi support but they told me to ship it 6hours away and it costs alot of money too i saw somewhere that some msi laptops have something called master password reach me out if you want more information on anything.
    thats all my specs:
    Serial Number: 9S7158212871ZLA000085 / K2110N0139122
    Product Name: Katana GF66 11UC
    OS: Microsoft Windows 11 Home 64-bit Ver.23H2(OS build 22631.5909)
    Windows Product Key: 49CHD
    HDI Build: ZS7-1582RM4-ZS1 / 12.1.I22.13.0.7
    BIOS Version: E1582IMS.314
    baseboard version rev:1
    BIOS Release Date: 2023/03/20
    EC Version: 1582EMS1.1070310202315:10:19
    CPU: 11th Gen Intel(R) Core(TM) i5-11400H @ 2.70GHz
    Memory: 16 GB @ 1600 MHz
    • 8192 MB, DDR4-3200, SK Hynix HMA81GS6DJR8N-XN
    • 8192 MB, DDR4-3200, Crucial Technology CT8G4SFRA32A.C8FP
    Graphics: Intel(R) UHD Graphics, 128 MB
    Graphics: NVIDIA GeForce RTX 3050 Laptop GPU, 3964 MB
    VBIOS Version: 94.07.3b.00.93
    Disk: SSD, Micron_2210_MTFDHBA512QFD, 476.94 GB
  • Answer selected by lagk0u at 10-11-2025, 02:50 PM.
    lagk0u
    • Oct 2025
    • 7
    • greece
    thats all my specs:
    MY PROBLEM GOT SOLVED AFTER 10 DAYS OF TRYING NON STOP THANKS TO A GUY CALLED "WRONG CHIP" I WANT TO SHOOTOUT HIS YT CHANNEL HE MANAGED TO GET MY PROBLEM SOLVED IN MINUTES I WANT TO SAY BIG THANKS TO ANOTHER GUY FOR TELLING ME TO WATCH ONE OF HIS VIDEOS MY PROBLEM IS NOW SOLVED THANK YOU EVERYONE HAVE A NICE LIFE.
    • shiyab
      • Sep 2023
      • 1696
      • india
      post backup bios and snid
      • lagk0u
        • Oct 2025
        • 7
        • greece
        where do i find those things can you pls tell?
        • peste
          • 13924
          • ROMANIA
          The bios chip must be unsoldered from the board before writing or reading..
          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
          solder wires between the programmer and the bios chip..
          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          • lagk0u
            • Oct 2025
            • 7
            • greece
            Soo the only way to bypass the password is to unsolder the bios chip from the motherboard rewrite it in this usb stick you send me and put back in?
            • peste
              • 13924
              • ROMANIA
              maybe someone else knows another method..
              • m1ch43lzm
                • Mar 2019
                • 1133
                • Peru
                You can try backing up your BIOS with FPT if you can boot into Windows normally (you only have BIOS setup password)
                Check this video for reference: https://www.youtube.com/watch?v=phNNZ3oGwP4
                Usage:
                Open command prompt as Administrator and run the following command
                Code:
                FPTW64.exe -BIOS -D BIOS_Region.bin
                Attached the required FPT version
                It will make a backup of the BIOS region only, not the full contents of the BIOS chip including Intel ME region
                The password may be possible to be decrypted from there, upload that file as .zip or .rar, someone will take a look and check if it's possible to decrypt and give you the password
                If it can't be decrypted (different encryption than the known method), the only option is the hardware programmer to read the existing contents of the BIOS chip, remove the password, flash the modified BIOS back, or take it to a laptop repair shop
                • lagk0u
                  • Oct 2025
                  • 7
                  • greece
                  Usage:
                  Code:
                  First of all thank you for your time you maybe have saved me 100€ do you know anyone who can decrypte it or i will just post it?.
                  • m1ch43lzm
                    • Mar 2019
                    • 1133
                    • Peru
                    Yes, attach it here, I or someone here will look at it
                    • lagk0u
                      • Oct 2025
                      • 7
                      • greece
                      i dont have the correct fpt version the guy in the video doesnt tell where i can find any links to download fpt and the version you send me is wrong where do i find?
                      • m1ch43lzm
                        • Mar 2019
                        • 1133
                        • Peru
                        I attached the correct FPT version for Intel 11th gen (Tiger Lake, ME 15.0.x), check if you have Intel Management Engine driver installed, should be listed under Device Manager - System Devices
                        Download and install the Intel Management Engine driver if you don't have it installed
                        https://www.msi.com/Laptop/Katana-GF...66-11UC#driver
                        Which error do you get on FPT?
                        You can search for "CSME system tools" if you need another version of the Flash Programming Tool, but I supplied the correct one according to your CPU type
                        • lagk0u
                          • Oct 2025
                          • 7
                          • greece
                          Brother i wanna thank you for giving me the youtube name link the guy called Wrongchip managed to find my password in 5 minutes with another program my problem is solved thanks everyone for trying to help.
                          • lagk0u
                            • Oct 2025
                            • 7
                            • greece
                            thats all my specs:
                              MSI Gaming Katana GF66 11UC-084CA Notebook GF Specification for Upgrade or Repair
                              This specification for the MSI Gaming Katana GF66 11UC-084CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Katana GF66 11UC-084CA boardview and Katana GF66 11UC-084CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-07-2024, 06:38 AM
                              MSI Gaming GF66 11UC-865XPL Katana Notebook GF Specification for Upgrade or Repair
                              This specification for the MSI Gaming GF66 11UC-865XPL Katana Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UC-865XPL Katana boardview and GF66 11UC-865XPL Katana schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-07-2024, 05:00 AM
                              MSI Gaming GF66 11UC-864XPL Katana Notebook GF Specification for Upgrade or Repair
                              This specification for the MSI Gaming GF66 11UC-864XPL Katana Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UC-864XPL Katana boardview and GF66 11UC-864XPL Katana schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-07-2024, 04:10 AM
                              MSI Gaming GF66 11UC-809NL Katana Notebook GF Specification for Upgrade or Repair
                              This specification for the MSI Gaming GF66 11UC-809NL Katana Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UC-809NL Katana boardview and GF66 11UC-809NL Katana schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-07-2024, 02:50 AM
                              MSI Gaming GF66 11UC-813NL Katana Notebook GF Specification for Upgrade or Repair
                              This specification for the MSI Gaming GF66 11UC-813NL Katana Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UC-813NL Katana boardview and GF66 11UC-813NL Katana schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
