Acer Aspire A715-42G EC Firmware needed
This topic has been answered.
  • ElMaDragon
    • Jun 2025
    • 7
    • Japan
    Model: Acer Aspire 7 A715-42G
    Board: GH5VZ LA-K831P(Manufacturer:ChuanYi)
    Specs: CPU:Ryzen5 5500U
    GPU:GTX1650 Laptop 4G RAM
    RAM: DDR4 8GB 3200Mhz(for testing)
    Strage:M.2 NVME 500GB(for testing)
    I would greatly appreciate it if someone could provide a dump of the EC (KB9022Q D) for this laptop.
    I recently purchased this laptop in a non-working condition. After checking for short circuits and verifying that all voltages are present and within expected ranges, I concluded that the power-on sequence is not progressing and the issue is likely with the EC.
    It appears that the EC may have been replaced previously, as there are visible signs of soldering on the chip. I inspected all EC input/output signals with an oscilloscope and found some unusual behavior—for example, signals that don’t make sense for this model's power sequence, and SPI signals coming from pins that aren’t used for SPI flash in this design.
    Based on this, I suspect the EC firmware is either missing or incorrectly programmed. That’s why I’m looking for a proper EC dump for this specific model.
    Thanks in advance for your help!
  • Answer selected by ElMaDragon at 06-26-2025, 10:38 AM.
    hoaca388
    Badcaps
    • Jan 2022
    • 11824
    Originally posted by ElMaDragon
    I'm sorry, but due to certain circumstances, I'm unable to share the BIOS backup.
    https://www.badcaps.net/forum/troubl...5-42g-la-k831p Based on the schematic posted on this forum, the BIOS ROM appears to be connected directly to the APU and not to the EC.
    So I believe the EC firmware is not included in the BIOS.
    Is it still possible to extract the EC firmware from the BIOS in this case?
    Here
    • hoaca388
      Badcaps
      • Jan 2022
      • 11824
      Model: Acer Aspire 7 A715-42G Board: GH5VZ LA-K831P
      It appears that the EC may have been replaced previously. I inspected all EC input/output signals with an oscilloscope and found some unusual behavior—for example, signals that don’t make sense for this model's power sequence, and SPI signals coming from pins that aren’t used for SPI flash in this design.
      You MUST:
      • Read BIOS guides, methods, resources and tools
      • Try the method at BIOS guides, methods, resources and tools before requesting help
      • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
      • Use search function in case someone already answered your request
      • Post under a related thread if it exists
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • Name your thread with make, full model numbers and request
      • Provide a BIOS/EC dump if possible
      • Attach files directly to your post instead of linking to external websites
      • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
      • ElMaDragon
        • Jun 2025
        • 7
        • Japan
        Originally posted by hoaca388
        You MUST:
        Sorry, I'll correct the board vendor and specifications.
          • 21058
          Can you post your bios backup, it might be possible to extract the EC from that.
          • ElMaDragon
            • Jun 2025
            • 7
            • Japan
            • hoaca388
              Badcaps
              • Jan 2022
              • 11824
              Here
              • ElMaDragon
                • Jun 2025
                • 7
                • Japan
                Here
                Thank you very much for the EC firmware. I’m sorry to bother you, but based on the pin configuration in the schematic, it seems that the KB9022Q D firmware for the Acer A715-42G might be customized.
                Is this firmware specifically customized for the KB9022Q D in the Acer A715-42G?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11824
                  I don't know, this is EC from Acer homepage .EXE file.
                  • ElMaDragon
                    • Jun 2025
                    • 7
                    • Japan
                    I have a quick question. You mentioned it was from the EC .EXE on Acer’s website — is it extracted from the BIOS***.EXE(*is version) file for the A715-42G?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11824
                      Yes.
                      • ElMaDragon
                        • Jun 2025
                        • 7
                        • Japan
                        Here
                        After flashing the firmware you kindly provided, the laptop successfully booted up. I can't thank you enough.
                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 02:30 PM
                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-06-2024, 05:27 AM
                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
