bios for lenovo yoga slim 6i 14iap8
  • henriquer53
    • Jul 2022
    • 7
    • brazil
    Hi everyone, please, i need this bios, my lenovo 14iap8 is stuck in recovery mode after shutdown in a bios update, thanks.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11813
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • henriquer53
      • Jul 2022
      • 7
      • brazil
      sorry, i tried to found a dump bios or get a bios to "reflash" , but it is stuck in recovery mode , in lenovo website i only got the files to update bios via windows
      My device informations :
      Model name : YOGA SLIM 6 14IAP8
      MO : PE9013906042
      MTM: 83C70001BR
      SN: PE0BDXG6
      i attached the file from lenovo bios update
      • shiyab
        • Sep 2023
        • 1495
        • india
        MO : PE9013906042
        MTM: 83C70001BR
        SN: PE0BDXG6
        hi flash both ic 8mb 16
          • 21032
          MO : PE9013906042
          MTM: 83C70001BR
          SN: PE0BDXG6
          If it`s stuck in recovery i think your only option is to buy an SPI programmer. Make backups of both chips before flashing any other bios, post the backups here and we can check if they are good or not, then we`ll tell you what to do next.
          • henriquer53
            • Jul 2022
            • 7
            • brazil
            hi, im going to test it
            • henriquer53
              • Jul 2022
              • 7
              • brazil
              yes im going to dump the 3 ic it got
              • henriquer53
                • Jul 2022
                • 7
                • brazil
                hi friend, good night , i want to thank you, thank you so much, you saved my day.
                I only flashed the 16mb and it works,
                I had to modify the ch341 for 3.3v and also im going to upload the dump i made from the 16mb chip.
                Thank you my friend.
                Hope you get a lot of good things in your life.
                • naujguerrero
                  • Jun 2025
                  • 4
                  • Mexico
                  Hello, can you reupload?, i cant download this file, thks.
                  • naujguerrero
                    • Jun 2025
                    • 4
                    • Mexico
                    My Lenovo Yoga Slim 6 14IRP8 - Type 82WV laptop is not boot up after BIOS update through Lenovo Vantage app.
                    It display a message box with a question "Do you want to recovery ROM Part? (Caution: Not every OS is bootable in Recovery Mode.)" With a couple of choices as below.
                    YES, this choice will flash ROM Part. NO, abort Recovery mode and restart system.
                    Both choices do not seem to work and the same message keeps appearing every time I restart. Even the novo button did not help and displays same message.
                    • peste
                      • Dec 2016
                      • 12882
                      • ROMANIA
                      post the contents of the bios chip even if it is corrupted..
                      post S/N, full name and model, motherboard model, TYPE,etc.
                      • naujguerrero
                        • Jun 2025
                        • 4
                        • Mexico
                        Hello, here is more info. Thanks.
                        ​​​​​Yoga Slim 6 14IRP8 - Type 82WV
                        Serial number: YX07B213
                        Processor: 1x 13th Generation Intel® Core™ i5-1340P Processor(Core™ i5-1340P)
                        Motherboard model: MB H82WVI51340P_UMA_16G_L_WINRM (Part number: 5B21J35939)
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11813
                          You MUST:
                          • VMINFO
                            • Apr 2023
                            • Brasil
                            Hello sir, can you please reupload? Need the same bios 8 + 16 mb but the download link is broken
                            • VMINFO
                              • Apr 2023
                              • Brasil
                              Hello ,
                              can someone upload a working bios for this laptop:
                              LENOVO YOGA 6 SLIM 14IAP8
                              MO - PE9014808058
                              MTM - 83C70000BR
                              SN - PE0CXC6Q
                              need the 8mb + 16mb bios please!
                              Thanks in advance
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11813
                                Originally posted by VMINFO
                                Hello ,
                                MO - PE9014808058
                                MTM - 83C70000BR
                                SN - PE0CXC6Q
                                Thanks in advance
                                See #13.
                                • beogeek
                                  Lenovo Yoga Slim 7 14APU8 Bios Request
                                  by beogeek
                                  I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                                  Attached is the bios dump in the state I received it...
                                  10-24-2024, 12:54 PM
                                  Lenovo Yoga Slim 7 Pro Notebook Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Slim 7 Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Slim 7 Pro boardview and Slim 7 Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                  09-07-2024, 07:20 AM
                                  Lenovo Yoga Slim 9 Notebook Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Slim 9 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Slim 9 boardview and Slim 9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Yoga Slim...
                                  Lenovo Yoga Slim 5 Notebook Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Slim 5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Slim 5 boardview and Slim 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Yoga Slim...
                                  09-07-2024, 06:38 AM
