Bios Samsung Galaxy Book3 NP754*** bios
  • igsnet
    • Mar 2019
    • brazil
    Hello, I need this bios with a clean region.
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Read the rules: https://www.badcaps.net/forum/troubl...before-posting
    Upload your original BIOS file (even if it's corrupted). Describe your issue, write your laptop model number and serial number.
    all donations are welcome,
    • igsnet
      • Mar 2019
      • brazil
      Original file, but corrupt.
      laptop model : Samsung Galaxy Book3 NP754XFG-KF1BR BA98-03971A10
      Motherboard : TITAN3_M Rev.MP1.0_22 / 12 / 15
      ​serial number : 0AR49QCW800178H
      Laptop turnes on, but not on the picture, all testes have already been done, it has all the voltages.
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        BA98-03971A10
        LAPTOP TURNES ON, BUT NOT ON THE PICTURE, ALL TESTS HAVE ALREADY BEEN DONE, IT HAS ALL THE VOLTAGES.
        Here is your new BIOS, try it and let me know.
        By the way, your original file has extra size 1KB (300h), I think this is happened because you choose (OTP).
        • igsnet
          • Mar 2019
          • brazil
          Thank you very much!! It worked! I'm very happy!
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            Great, you're welcome.
            • alexs1984
              • Jul 2022
              • 5
              • Argentina
              BIOS Samsung Galaxy Book3 NP754XGK MB TITAN4_M REV.MP1.0_12/23/01
              Hi, I need this BIOS with a clean region. Because I forgot the BIOS password.
              • peste
                • 13661
                • ROMANIA
                post the original contents of the bios chip..post S/N..
                • alexs1984
                  • Jul 2022
                  • 5
                  • Argentina
                  Hello, good morning
                  Laptop model:
                  Samsung Galaxy Book3​ NP754XGK-KG1ES
                  SAMSUNG PO BOX 12987 DUBLIN /YATELEY GU466GG. UK
                  MOTHERBOARD MODEL
                  TITAN4 NB6099C_PCB_MB_MP1.0
                  REV: MP1.0_23/12/01
                  SERIAL NUMBER KY6W99YX20007WR 02.2024
                  ORIGINAL FILE ATTACHED
                  I HOPE YOU CAN HELP ME THANK YOU VERY MUCH
                  • shiyab
                    • Sep 2023
                    • 1622
                    • india
                    Hello, good morning
                    Laptop model:
                    Samsung Galaxy Book3 NP754XGK-KG1ES
                    MOTHERBOARD MODEL
                    REV: MP1.0_23/12/01
                    try
                    • alexs1984
                      • Jul 2022
                      • 5
                      • Argentina
                      Hello, I have a problem: the keyboard turns on and the blue light flashes, then turns off, and the screen goes black. Could it be a programmer error or the program I'm using? I await your response. Thank you.
                      • shiyab
                        • Sep 2023
                        • 1622
                        • india
                        flash olde faile
                        • alexs1984
                          • Jul 2022
                          • 5
                          • Argentina
                          Hello, is there any solution to fix this error that appears because before it turned on normally, only that the BIOS had a password? I hope you can help me, thank you very much.
                          I'm using CH341B-NeoProgramer full for programming.
                          • volinakis
                            • Jan 2021
                            • 2874
                            • N/A
                            so, your bios works but has password, right?
                            use this file
                            • alexs1984
                              • Jul 2022
                              • 5
                              • Argentina
                              Hello colleagues, the problem persists. When I turn it on, the keyboard lights up, the processor activates and heats up, and the heatsink fan starts, but there's no image on the screen. The power light flashes for a few seconds and then goes off. If I try to turn it on again, it does the same thing. I ​should mention that the machine used to start up fine; it only had a BIOS password. But when I tried to re-flash the old firmware, this problem started. I'm using a CH341A programmer and the CH341 version 1.9 software. Could I be doing something wrong? I look forward to your reply. Thank you.
                                09-07-2024, 05:50 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
                                Samsung Galaxy Book3 Pro Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book3 Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung Galaxy Book3...
                                09-07-2024, 07:20 AM
                                Samsung Galaxy Book3 Pro NP940XFG-KC2NL Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book3 Pro NP940XFG-KC2NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP940XFG-KC2NL boardview and NP940XFG-KC2NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 07:19 AM
                                Samsung Galaxy Book3 NP750XFG-KA3DE Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book3 NP750XFG-KA3DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP750XFG-KA3DE boardview and NP750XFG-KA3DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
