lenovo p15v gen 3 enrollment or mdm
    please can anyone remove the enrollment or mdm from this bios. thanks
    lenovo p15v gen 3
    sn : PF-43ZJX6
    board : JP6A0/JT6A0 NM-E221 Rev: 1.0
    lenovo p15v gen 3
    sn : PF-43ZJX6
    computrace and autopilot remove
    EDIT .take new file .
      the laptop not powering on with this dump
        try only autopilot
        Have you enabled computrace in the bios?
        or you have a problem installing windows
          a variable that forces you to connect to the internet is also present.
          I have not deactivated it yet
            try only autopilot
            Pls check dump and patched files are same on Hex. Can you verify.
              yes mistake .
                try
                  try
                  I will try now and updat you
                    I think i did something wrong , because i get only 2 volts on bios chip
                    i will attach another bios with same mdm problem
                    lenovo p15v gen 3
                    sn : PF-4QFFJK
                    board : JP5A5 NM-E711 rev :1.0
                      lenovo p15v gen 3
                      sn : PF-4QFFJK
                      Try and Update.
                        Try and Update.
                        Same result I can't bypass network when i setup windows
                          lenovo p15v gen 3
                          sn : PF-4QFFJK
                          your file not fully read.
                            OK i will read it again
                              i read it again
                                i read it again
                                Still its not read correctly.
                                  i read it with an other programmer
                                    try
                                    after i fix the first lenovo . i reflash with this dump and its working perfect thank you so mush bro
                                      thanks for feedback
