Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
  • HotSaladMan
    • Sep 2022
    • 10
    • mexico
    *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
    Model : Lenovo ThinkBook 14S Yoga ITL
    S/N : MP28JT19
    MFG Date : 2022/02/09
    Factory ID PRC4
    MO : MPNXB26080FX
    MTM : 20WE001US
    MODULE FCC ID : PD9AX201NG
    IC : 1000M-AX201NG
    BOARD INFO
    FLV34 LA-KO51P
    REV : 1B 2020-08-24
    Bit of Info
    Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
    chip id, so i would always uncheck the id check, so it would bypass the error
    i did in fact make backups, they are attached, unfortunately i didn't know how to make them properly,
    so i made both 8mb an 16mb types of both the chips, again, i gave it my best
    those are the only backups i made
    Using a backup i found in this post
    HTML Code:
    https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/97234-lenovo-thinkbook-14-g2-itl-flv34-la-k051p-bios
    #9 i made the attempt to flash those files to the chips in the machine, i was able to locate
    the bios chips from said machine in the same thread post #73, theirs an image where it locates them for me
    Unfortunately once i did the flash with those bios, it just turns on the power light comes on along with ESC an CAPS LOCK
    an screen stays black, i failed to read up on anything, in my hurry to get the job done, i went ahead an read up on the best programmer to use, i ended up buying a T48 Tl866-3g
    i flashed another bios, then another, an another, now the screen still stays black, but the power light comes on an off an loops, no more ESC or CAPS LOCK lights thou so at least im guessing that's an error less
    iv attached everything needed for proper help, those bios are the only ones i made before flashing incorrect files
    I currently due have the best recommended programmer by this forum, i now have a hot air station so i can now de-solder an re-solder, along with the proper adapters
    so the programmer can best read the chips, thou i em aware i should have had them before hand
    I em open to being roasted by the community members as i did a half ass job
  • HotSaladMan
    • Sep 2022
    • 10
    • mexico
    Help?
    • danito
      • Jun 2016
      • 1039
      • Romania
      Originally posted by HotSaladMan
      Help?
      try
      • HotSaladMan
        • Sep 2022
        • 10
        • mexico
        Originally posted by danito
        try
        ill give it a shot, im heading to my shop right now, thanks
        • nasirahmad53
          • Sep 2023
          • 20
          • Bangladesh
          ThinkBook 14s Yoga ITL -
          Type 20WE
          FLV34 LA-K051P
          Bios Password
          Hello, can you unlock this bios password please.......
          SN : MP1ZTKP8
            SMDFlea commented
            Editing a comment
            Post moved to 14S Yoga ITL topic.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12073
          Type 20WE
          FLV34 LA-K051P
          Bios Password
          SN : MP1ZTKP8
          Xiaoxin Air-14 2021 (Intel platform: ITL version) new bios
            SMDFlea commented
            Editing a comment
        • nasirahmad53
          • Sep 2023
          • 20
          • Bangladesh
          after write bios, continue restart problem
          • hoaca388
            Badcaps
            • Jan 2022
            • 12073
            Strange, this is the bios I found by your serial number, it's a new bios.
            • nasirahmad53
              • Sep 2023
              • 20
              • Bangladesh
              i tried others bios but ssd not detect,
              when i programme your bios , laptop continue restart
              • hoaca388
                Badcaps
                • Jan 2022
                • 12073
                Maybe EC need added.
                  • 21417
                  Type 20WE
                  FLV34 LA-K051P
                  Bios Password
                  SN : MP1ZTKP8
                  Post the serial number again, check it carefully
                  • nasirahmad53
                    • Sep 2023
                    • 20
                    • Bangladesh
                    Extremely sorry , it's my mistake
                    i give you wrong serial number......
                    you are genius
                    SN : MP1ZTKPB
                      • 21417
                      you are genius
                      SN : MP1ZTKPB
                      Flash your bios backups back again, check if it boots up ok, then post your EC backup.
                      • nasirahmad53
                        • Sep 2023
                        • 20
                        • Bangladesh
                        i don't have EC programmer now, ssd not detect after write others bios, i can enter bios , but ssd not detect....
                        please unlock
                        SN : MP1ZTKPB
                        • volinakis
                          • Jan 2021
                          • 2790
                          • N/A
                          please unlock
                          SN : MP1ZTKPB
                          try
                          • nasirahmad53
                            • Sep 2023
                            • 20
                            • Bangladesh
                            Originally posted by volinakis
                            try
                            Thank you very much brother, it's work perfectly, also detect SSD, thanks again
                            Badcaps Legend are Genius
                            • volinakis
                              • Jan 2021
                              • 2790
                              • N/A
                              you are welcome
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                                Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 14s Yoga ITL boardview and ThinkBook 14s Yoga ITL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 04:10 AM
                              • abhorsen
                                Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                by abhorsen
                                Hey guys,
                                Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                07-06-2023, 10:22 AM
                              • neaw
                                thinkbook 14s yoga itl BIOS
                                by neaw
                                I have a thinkbook 14s yoga itl
                                I need to put the computer's original BIOS back.
                                I have this bios installed
                                Bios version: F8CN53WW(V2.16)
                                MTM: 20WE0001SP
                                and corresponds to another model Thinkbook-14-G2-ITL
                                The corresponding bios is FNCN44WW but it won't let me install it.
                                Where you can get the bios in BIN format.
                                The problem I have is that now the Touch Screen does not work....
                                01-05-2024, 11:23 AM
