ACER chromebook c733 Enterprise Enrollment
  • hichamhb
    • Jun 2019
    • 94
    • morocco
    Device : Laptop
    Brand : acer
    Model : chromebook c733 (N18Q5)
    Board Number : da0zakmb6e0
    Request : remove Enterprise Enrollment
  • peste
    • Dec 2016
    • 13904
    • ROMANIA
    Originally posted by hichamhb
    Device : Laptop
    Brand : acer
    S/N???
    • hichamhb
      • Jun 2019
      • 94
      • morocco
      Originally posted by peste
      S/N???
      S/N : NXH8VEB0080211FE8D7600
      SNID : 02113070176
      Thanks in advance
      • volinakis
        • Jan 2021
        • 2875
        • N/A
        SNID : 02113070176
        Thanks in advance
        reinstall from USB stick made with Chromebook Recovery utility for your model
        • hichamhb
          • Jun 2019
          • 94
          • morocco
          its working thank you
          • volinakis
            • Jan 2021
            • 2875
            • N/A
            you are welcome
            • hichamhb
              • Jun 2019
              • 94
              • morocco
              I have acer c733 series chromebook with enterprise lock.
              model; C733-C3UY
              SN; NXH8VEB008035202137611
              Board serial no; ZAK DA0ZAKMB6J0 REV J​
                SMDFlea commented
                Editing a comment
                Thread merged...
            • Heaton41
              • Aug 2024
              • 5
              • Algeria
              For your request acer c733 series chromebook with enterprise lock.
              After flash the bios reset the chromeOS don't turn on directly Good Luck
              • hichamhb
                • Jun 2019
                • 94
                • morocco
                thank you its working
                • Visko127
                  • Dec 2024
                  • 4
                  • Croatia
                  Request: Remove Enterprise Enrollment
                  Acer Chromebook C733 Series (C733-C9CU)
                  Model: N18Q5
                  S/N:NXH8VED01G0280560D7611
                  SNID:02802202976​
                  Thank you in advande
                    SMDFlea commented
                    Editing a comment
                    post your backup, can`t do anything without that.
                • Visko127
                  • Dec 2024
                  • 4
                  • Croatia
                  Sorry, here's the backup
                  • volinakis
                    • Jan 2021
                    • 2875
                    • N/A
                    • Visko127
                      • Dec 2024
                      • 4
                      • Croatia
                      Thank you very much, I have flashed the BIOS, but now I have a problem, the blue power light comes on then disappears and them comes back on again and after 20 seconds only some colored lines appear on the screen. Hopefully bad soldering or didn't put a cable back in correctly, will check everything tomorrow and write the results.
                      • volinakis
                        • Jan 2021
                        • 2875
                        • N/A
                        put back original bios and if laptop doesn't start it means you read bios chipset with errors
                        • Visko127
                          • Dec 2024
                          • 4
                          • Croatia
                          Hi,sorry for the delay on response. I reflashed the bios, freshly installed the OS and now it works perfectly,thank you very much
                          • naruegy
                            • Aug 2021
                            • indonesian
                            model; C733-C6X2
                            SN; UNAZDSD00422708D810601
                            Board serial no; ZAK DA0ZAKMB6KO REV K​
                            • volinakis
                              • Jan 2021
                              • 2875
                              • N/A
                              model; C733-C6X2
                              here. reinstall from USB stick made with Chromebook Recovery utility for your model
                              • Tomtom 1212
                                • Sep 2024
                                • indonesia
                                Acer Chromebook C733 Series (C733-C3JA)
                                Model: N18Q5
                                S/N:NXH8VSN004115205337611
                                SNID: 11513240376
                                Thank you​
                                • peste
                                  • Dec 2016
                                  • 13904
                                  • ROMANIA
                                  Model: N18Q5
                                  SNID: 11513240376
                                  Thank you​
                                  post the original contents of the bios chip..
                                  • AJ_1
                                    • Oct 2023
                                    • 18
                                    • Ghana
                                    Acer Chromebook C733 Series (C733-C962)
                                    Model: N18Q5
                                    S/N:NXH8WAA00301222F1C7600
                                    SNID:01214313276
                                      Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) Spin 513 Specification for Upgrade or Repair
                                      This specification for the Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Enterprise Spin 513 R841T boardview and Acer Chromebook Enterprise Spin 513 R841T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                      09-07-2024, 01:30 AM
                                      Acer Chromebook Enterprise 314 C933T-C5HP Chromebook Specification for Upgrade or Repair
                                      This specification for the Acer Chromebook Enterprise 314 C933T-C5HP Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise 314 C933T-C5HP boardview and Enterprise 314 C933T-C5HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-07-2024, 02:00 AM
                                      Acer Chromebook Enterprise 314 C933LT-P0AB Chromebook 314 Specification for Upgrade or Repair
                                      This specification for the Acer Chromebook Enterprise 314 C933LT-P0AB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise 314 C933LT-P0AB boardview and Enterprise 314 C933LT-P0AB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-07-2024, 12:10 AM
                                      Acer Chromebook Enterprise Spin 513 R841T-S7SQ Chromebook Spin 513 Specification for Upgrade or Repair
                                      This specification for the Acer Chromebook Enterprise Spin 513 R841T-S7SQ Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise Spin 513 R841T-S7SQ boardview and Enterprise Spin 513 R841T-S7SQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                      09-06-2024, 11:40 PM
                                      Acer Chromebook Enterprise Spin 514 CP514-1W-R9VE Chromebook Spin 514 Specification for Upgrade or Repair
                                      This specification for the Acer Chromebook Enterprise Spin 514 CP514-1W-R9VE Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise Spin 514 CP514-1W-R9VE boardview and Enterprise Spin 514 CP514-1W-R9VE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-06-2024, 11:20 PM
