HP EliteBook 840 G8 hp wolf security removal
  • djimy
    • Sep 2019
    • 8
    • dzdz
    i have an hp elitebook 840 g8 that used to belong to a company i bought it second hand it has no password on the bios but after installing windows and connecting it to the internet it get locked by hp wolf security the only solution i found is installing linux on it but when installing windows it get locked after using for a few hours i could not find how to disable it on the bios settings if anyone know how to remove this i attached a bios dump and the motherboard info
    CORVETTE-6050A3217501-MB-A01 (A1)(1086) L2​
  • djimy
    • Sep 2019
    • 8
    • dzdz
    This is an image of it when it get locked
      • 20984
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • djimy
        • Sep 2019
        • 8
        • dzdz
        Hp elitebook 840 g8
        prodid 3F7E9UC#ABB
        Sn# 5CG147DOLX
        Warranty 3y3y0y
        • minhdigital
          • Nov 2022
          • 757
          • Vietnam
          Originally posted by djimy
          Hp elitebook 840 g8
          prodid 3F7E9UC#ABB
          Sn# 5CG147DOLX
          Warranty 3y3y0y
          Send to you, try
          • PTR215
            • Nov 2019
            • 5
            Hello, I have the EliteBook 840 G8 Wolf Security version. The winbond chip is bios admin locked. Would I be able to rewrite with stock bin. ? Or is the dump the only bin. I can use? Thank you in advance!
            • peste
              • Dec 2016
              • 12859
              • ROMANIA
              post S/N, full name and model, motherboard model, product number,etc.
              post the original contents of the bios chip..you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
              • PTR215
                • Nov 2019
                • 5
                S/N 5CG21309K6
                Model HP EliteBook 840 GB
                Exact Model HP Elitebook 840 G8 Notebook PC Wolf Pro Security Edition (613P6UT)
                MB Model 6050A3426501 - MB - A02 Corvette - PMV - AVARY
                ProdID (613P6UT#ABA)
                I will remove the winbond ship shortly to get info off chip.
                Thank you!
                • PTR215
                  • Nov 2019
                  • 5
                  I finally got the bin file, I am now having issue with uploading file into the forum......what is the process of uploading a file. I do not see the option in the interface, only link or image file upload options
                  • PTR215
                    • Nov 2019
                    • 5
                    I had to compress thank you!
                      • 20984
                      try this one
                      • geraldlua02
                        • Mar 2023
                        • 10
                        • Philippines
                        Sir Good Day. I have a EliteBook 840 G8 which have a HP Wolf Security and a SWAT LOCK issue. Hopefully someone can help me removing it.
                        Thank you in advance sir's! Godbless you all.
                        Model HP EliteBook 840 G8
                        PROD ID: 3K0M1UC#UUF
                        SN: 5CG21146BB
                        BOARD CODE: HP 6050A3426501-MB-A02 (1086) L2
                        I DROPED THE SWAT LOCK ISSUE BELOW.
                        THANKS YOU ONCE AGAIN.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11798
                          SN: 5CG21146BB
                          HP EliteBook 840 G8 Notebook PC
                          BuildId_21WWCVET601#SUUF#DUUF
                          Serial_5CG21146BA
                          Sku_3K0M1UC#UUF
                          CT Number_6LGWUNHGWFYT4K
                          Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
                          • geraldlua02
                            • Mar 2023
                            • 10
                            • Philippines
                            Serial_5CG21146BA
                            Sku_3K0M1UC#UUF
                            Good Day sir!
                            I programmed this to my bios but when I Press the power button it displayed ''recovering the old bios'' something like that cause it says i programed the wrong ones. It automatically recovers its old bios.
                            and then when i checked it the bios really came back to its own bios not this details below
                            -BuildId_21WWCVET601#SUUF#DUUF
                            -Serial_5CG21146BA
                            -Sku_3K0M1UC#UUF
                            -CT Number_6LGWUNHGWFYT4K
                            -Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g​
                            So technically it still has the swatlock problem. still thank you sir for trying to help me. I really appreciate it.
                            incase if someone still wants to help me, I dropped the EC BIOS AND MAIN BIOS below cause i think it might be needed. thank you so much po! salamat ng marami
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11798
                              Good Day sir!
                              -Serial_5CG21146BA
                              -Sku_3K0M1UC#UUF
                              HP EliteBook 840 G8 Notebook PC (3K0M1UC)
                                HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:50 AM
                                HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:20 AM
                                HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
