Samsung Galaxy book NP950XDB need Previous BIOS request
  • dragon2224
    • Dec 2022
    • ireland
    Hi, after automatic BIOS update with win11, my camera and keyboard baclight adjust stops working. Looking for previous BIOS version, to use SP programmer and downgrade it. Laptop details : Samsung Galaxy book NP950XDB-KE2UK , SN : 5D9Z9FFT100077A.
    Actual BIOS version is : P14RFW.070.240416.SP.
    Dump file from chip gigadevice 25R127D with actual BIOS attached. Many thanks !
  • dana.repouille
    • Feb 2023
    • 39
    dragon2224 Thanks for posting this. I can't help you, but you helped me a little. I am working for a local computer repair shop. They gave me a Samsung Galaxy Pro 15.6, NP950XDB-KC3US that will not POST. It powers on, but displays nothing on the screen. It just continues to flash the blue LED on the left side until I force it to power off.
    Using my T48 programmer, I was able to dump the Winbond 25Q80DVNIG chip to a 1MB file. However, my T48 and the Xgpro software refuse to recognize the GigaDevice 25R127DSIG chip. I am afraid that chip may be damaged.
    Did you remove the GigaDevice chip from the motherboard and insert it into your programmer, or did you use the clip?
    Wish I could help you!
    • noname2024
      • Aug 2024
      • 257
      • CỎ MỸ XỊN
      try
      [950XDB] Venus-15 TGL BIOS (P12RFW)
      [950XDB] Venus-15 TGL BIOS/MICOM Approval Ver.13 (P13RFW)
      • dana.repouille
        • Feb 2023
        • 39
        I doubt this will help, but I have uploaded a BIOS dump from a Galaxy Book Pro that does NOT POST. I hope I can get it cleaned one day, but I need to find a dump of a working BIOS for this model. The Venus-15 BIOS dumps may work. I will try them.
        NP950XDB-KC3US
        Serial Number 5BSK9FERC00150K
        GigaDevice 25R127DSIG WFK588 AU212P
        • noname2024
          • Aug 2024
          • 257
          • CỎ MỸ XỊN
          The bios I send is based on the bios build code and model code on the server for Samsung's repair technicians. It is a factory bios that follows the monthly version update mode. The original factory bios
          • dragon2224
            • Dec 2022
            • ireland
            I was using ch341a usb programmer, no clip, but unsolder bios chip method. Can I use Venus-15 TGL BIOS on my Galaxy book Laptop ?
            • dana.repouille
              • Feb 2023
              • 39
              Originally posted by noname2024
              try
              Thank you for these files The P12RFW file contains a 16MB P12RFWB.bin file, which looks promising. It just needs to have the model, serial number, and Windows product key copied into it.
              The P13RFW may be corrupted. Windows File Explorer could not open it, so I had to use 7-zip. It contains a P13RFW.bin file that is only 10MB in size, and appears to be incomplete.
              Thanks again.
              • dana.repouille
                • Feb 2023
                • 39
                ​Actual BIOS version is : P14RFW.070.240416.SP.
                This Venus motherboard has two BIOS chips: a 16MB GigaDevice near the CPU, and a 1MB Winbond near the edge of the laptop. I am not sure where to get the 1MB BIOS, which I believe is for the Embedded Controller (EC).
                Dana
                  • 21133
                  NP950XDB-KC3US
                  Try this bios.
                  • dana.repouille
                    • Feb 2023
                    • 39
                    SMDFlea Thanks for that clean P13 version BIOS. Thank you for copying the serial number and Windows key.
                    I haven't had a chance to try it yet, but I plan to try it soon. I can't use a clip to flash this chip in circuit, so I must desolder it from the board each time.
                    Your NP950XDB_P13RFW ME_Clean.bin contains:
                    P13RFW 068 2024 01 25 SP 950XDB
                    My original NP950XDB-BAD-GD25R127D.BIN contains:
                    P14RFW 070 2024 04 16 SP 950XDB
                    This is not my laptop, so I can only guess that the update to P14 failed, leaving a corrupted BIOS.
                    I have heard that Samsung BIOS images can be downloaded from the Microsoft update catalog, but you have to know the GUID to find them.
                    • dana.repouille
                      • Feb 2023
                      • 39
                      SMDFlea Your clean P13 BIOS has the same symptoms as the other clean BIOS images I have applied. At this point, I must assume that the board has some other failed component, and the symptoms are not due to a corrupted BIOS. Luckily, I have a replacement motherboard on the way, and it should arrive either today or on Monday.
                      My NP950XDB-KC3US board does charge the battery from USB-C just fine. However, it will not POST. It just keeps blinking the blue LED continuously until I force power off again. So it seems this board will just be a parts donor.
                      • dana.repouille
                        • Feb 2023
                        • 39
                        dragon2224 I hope I have not hijacked your thread with my own problems. I agree that the GigaDevice chip on this board cannot be programmed using a clip. My T48 programmer cannot detect the GigaDevice chip using a clip, but it can detect the smaller Winbond chip using a clip connection. As SMDFlea has said, that smaller Winbond chip is probably for the USB-C or Thunderbolt controller.
                        • jenek
                          • Apr 2014
                          • Russia
                          Samsung Galaxy book NP950XDB-KC4US
                          SN unknown, no back case.
                          Motherboard BA41-02882c Venus 13_15
                          Need help to repair my bios dump for laptop.
                          it was water damaged and i repaired motherboard succesfully.
                          bios stuck on samsung logo (Orig.rar dump)
                          Tried other dump(np950xdb Working) from this forum, and i can get into bios ,but:
                          -nvme not recognized
                          -very slow initialization
                          -it reboots instead of power-off state.
                          MB: BA41-02882c Venus 13_15
                          any way to get it back to life??
                          Attach my old non working dump, working dump from other mashine, and i also have Factory firmware (with it mashine reboots after samsung logo)
                          please help me to repair my ORIG dump for full working mashine
                          • peste
                            peste commented
                            Editing a comment
                            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                        • peste
                          • 12925
                          • ROMANIA
                          bios stuck on samsung logo.
                          Tried other dump from this forum, and it worked,but:
                          post S/N, full name and model, motherboard model, etc.
                            Samsung Galaxy Book Pro NP950XDB-KE4DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP950XDB-KE4DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XDB-KE4DE boardview and NP950XDB-KE4DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 06:11 AM
                            Samsung Galaxy Book Pro NP950XDB-KC3SE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP950XDB-KC3SE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XDB-KC3SE boardview and NP950XDB-KC3SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 05:50 AM
                            Samsung Galaxy Book Pro NP950XDB-KE6DE Netbook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP950XDB-KE6DE Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XDB-KE6DE boardview and NP950XDB-KE6DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 05:00 AM
                            Samsung Galaxy Book Pro NP950XDB-KE2UK Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP950XDB-KE2UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XDB-KE2UK boardview and NP950XDB-KE2UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 03:10 AM
                            Samsung Galaxy Book Pro NP950XDB-KC1IT Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP950XDB-KC1IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XDB-KC1IT boardview and NP950XDB-KC1IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 02:50 AM
