Acer Nitro v15 ANV15-51
  • CompHobbyist
    • Jun 2025
    • 9
    Thank you very much!. The password has been removed! I will make a donation to the forum as thanks!
    • Chrisnoronha
      • Jul 2025
      • Brazil
      #142
      Hi, could you guys please help unlock mine?
      Acer Nitro V 15 ANV15-51-57WS
      SB: NHQQDAL00442800A889Z00
      SNID: 428002696935
      • hoaca388
        Badcaps
        • Jan 2022
        • 12421
        #143
        SNID: 428002696935
        You MUST:
        • Read BIOS guides, methods, resources and tools
        • Try the method at BIOS guides, methods, resources and tools before requesting help
        • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
        • Use search function in case someone already answered your request
        • Post under a related thread if it exists
        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        • Name your thread with make, full model numbers and request
        • Provide a BIOS/EC dump if possible
        • Attach files directly to your post instead of linking to external websites
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
        • Prikol4eg
          • Aug 2025
          • Россия
          #144
          HELP UNLOCK
          acer nitro v15
          anv15-51-55m2
          SN: NHQNCER002412212747600
          snid: 4121357976
          DA0ZYPMBAF0 REV F
          • shiyab
            • Sep 2023
            • 1656
            • india
            #145
            Originally posted by Prikol4eg
            HELP UNLOCK
            acer nitro v15
            anv15-51-55m2
            snid: 4121357976
            DA0ZYPMBAF0 REV F
            try
            • RafiManch
              • Jul 2020
              • 6
              I have laptop with problematic BIOS.
              Acer Nitro V15
              S/N: NHQNCEK009522235557600
              ANV15-51-51GU
              Mobo: DA0ZYMBAG0 Rev.G
              User has tried to update BIOS and now laptop starts but screen stays black.
              Can someone please verify and fix the BIOS file please ?
              Thank you.
              • lapfix
                • Mar 2020
                • 2765
                • my workshop
                #147
                Acer Nitro V15
                ANV15-51-51GU
                Thank you.
                Try this virgion bios and give feedback
                • RafiManch
                  • Jul 2020
                  • 6
                  Hi, Thank you for your support.
                  I have tried provided BIOS.
                  Laptop did restart a few times but final was the same (black screen).
                  Could this be a problem with ME Region please ?
                  • lapfix
                    • Mar 2020
                    • 2765
                    • my workshop
                    #149
                    No , the one i post it is Configured and the same version 1.31
                    • RafiManch
                      • Jul 2020
                      • 6
                      Ok. I understand. I want to try FN+ESC function to use BIOS Crisis Recovery Mode.
                      Is there file .fd as part of your extraction or can I change .bin to .fd and use it please ?
                      .fd format is required to be added to USB stick in order to start recovery process.
                      Thank you.
                        • 22141
                        Acer Nitro V15
                        ANV15-51-51GU
                        Mobo DA0ZYXMBAF0 ??? .The bios you posted is ZYP V1.26 .Check the motherboard model number again
                        • RafiManch
                          • Jul 2020
                          • 6
                          File ''BIOS Acer Original'' is a dump file from the laptop.
                          Laptop is a model from 2025 (latest revision of motherboard).
                          Motherboard is:
                          Model: ZYP
                          DA0ZYPMBAGO Rev.G
                          • RafiManch
                            • Jul 2020
                            • 6
                            Motherboard is:
                            Model: ZYP
                            DA0ZYPMBAGO Rev.G
                            Hi Everyone,
                            It looks like BIOS version 1.26 and above could have problems.
                            There is many reports what I have found on internet.
                            Possibly version 1.26 has been removed from Acer support site.
                            Very likely version 1.31 can have problems too.
                            Can someone please provide virgin bios extracted from version 1.25 ?
                            Thank you.
                            • johnythegreat
                              • Jan 2021
                              • 4
                              • Phillipines
                              #154
                              Originally posted by thanhuiui01
                              It's a pity it failed.
                              did you find ecrom for this? can you help me because i need it too.
                              • Efrainzm
                                • Feb 2025
                                • 3
                                • Michoacan
                                #155
                                Originally posted by shiyab
                                hi try and feedback
                                hi friend, do you have this file?
                                • Efrainzm
                                  • Feb 2025
                                  • 3
                                  • Michoacan
                                  #156
                                  hi try
                                  hi friend, do you have the file EC_REG
                                  • shiyab
                                    • Sep 2023
                                    • 1656
                                    • india
                                    #157
                                    yes..
                                    • Efrainzm
                                      • Feb 2025
                                      • 3
                                      • Michoacan
                                      #158
                                      yes..
                                      THANKS, can you share it friend
                                      • shiyab
                                        • Sep 2023
                                        • 1656
                                        • india
                                        #159
                                        post snid
                                        • cachetop
                                          • Jun 2014
                                          • 7
                                          • hungary
                                          #160
                                          Hi!
                                          Please help me remove bios password.
                                          Acer Nitro V15 51 78CQ S/N: NHQNBEU0083360A1257600 Board: DA0ZYPMBAE0 REV E cpu: SRMJ0 VGA: GN21-X2-K1-A1
                                          Thank you!
