Hi everyone, I bought a Surface Laptop Go 2 but it has a UEFI password lock and Linux encrypted with a password is installed on its disk. I can only access the grub text menu. I think the recovery partition has been deleted. Booting from USB is disabled. Is there any hope or should I send it to a service center to reprogram the bios? Thank you
surface laptop go 2 uefi password
Originally posted by dedoshop View PostHi, this is my microsoft surface laptop go2 with sn 0B33CC3220737H bios dump. Is possible remove the bios password? Thanks in advanceAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by dedoshop View PostI'm became crazy; dumped with wellon progammer, reprogram with ch341a and also with original dump that i've attacched blank screen after initial pc logo. Also press the volume + or - after power (is laptop with keyboard) same result. Some solution?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi All i getting problem to install windows write protected i also used attributes commends on diskpart so may be it need bios clean or need dump working from other surface go 2
here is i attached 100% working but just got this problem write protected kindly share new on or clean this
Surface Go 2-1901 128 GB S/n 018464502551
Thank youAttached Files
Hey u (more) experienced guys'n'galls (than me) out there,
I'm stuck!
I managed to dump my BIOS, opened it in HxD, found the S.y.s.t.e.m.S.u.p.e.r.v.i.s.o.r.P.w.-section, but nothing I've tried furtheron got me into unrestrited UEFI. And I've read a couple of hours for now.
Would you please enlighten me by checking my dump? Your help would really be appreciated!
It's a Surface Go 2 LTE, it's sn is 000002513551.
kindest regards
SAttached FilesLast edited by 30NEM4n; 08-17-2024, 07:07 PM.
