acer chromebook c933 - enrolment problem
  • darckreign1984
    • 260
    DA0ZBCMB6D0 REV D
    QR CODE NBHKD110100
    3434BB47600
    CHROMEBOOK its already enrolled, tried to edit myself the bios, reinstaled the os, without succes.
    can someone guide me ? or edit this bios and remove my problem?
    thanks
  • Gcs_rma
    Banned
    • Dec 2023
    • 108
    • N/A
    Bios +ec
    • darckreign1984
      • 260
      Originally posted by Gcs_rma
      Bios +ec
      thanks for help
      i try only the bios bin / the laptop cant conect to internet after (wifi its recognized, i input the password , no internet) - cant reach google
      ec flash - i dont know what chip to flash
      • minhdigital
        • Nov 2022
        • 778
        • Vietnam
        Originally posted by darckreign1984
        DA0ZBCMB6D0 REV D
        QR CODE NBHKD110100
        3434BB47600
        thanks
        Send to you, try
        • darckreign1984
          • 260
          Originally posted by minhdigital
          Send to you, try
          with this file the laptop have internet, buth go again to enrolment process.
          • Gcs_rma
            Banned
            • Dec 2023
            • 108
            • N/A
            thanks for help
            Write ID MAC Lan.
            • darckreign1984
              • 260
              Write ID MAC Lan.
              wi-fi mac C8:B2:9B:CA:B9:76
              i used this tutorial, i change SN, then reset. now its downloading an update.
              1. After it boots into developer mode, press CTR+ALT+F2 the key, this should open a terminal
              2. In the terminal type "chronos"
              3. Then "sudo su"
              4. Then "vpd -l"
              On the displayed list you are looking for "serial_number"
              To change the entry do the following:
              vpd -s "serial_number"="enter your preferred serial"
              After that type:
              "dump_vpd_log --force"
              Then verify that the serial numbers have changed by typing "vpd -l" again
              Then reboot the chromebook by pressing REF+POW"
              for sudo su did not work - only "sudo -i"
              • darckreign1984
                • 260
                bad type "sudo -l"
                • osman68i
                  • May 2015
                  • 360
                  • The Netherlands
                  try with your edited bios
                  you must create usb recovery disk.
                  and then
                  • Turn off your Chromebook
                  • Holding Esc + Refresh (F3) buttons while pressing Power button. Then release Power Button.
                  insert usb and install new os
                  • darckreign1984
                    • 260
                    and then
                    tested your solution. I get rid off developer mode.
                    it worked.
                    Can you help me with a second one?
                    thanks in advance
                    • Aries Molinar
                      • Jan 2024
                      • 12
                      • Philippines
                      it worked.
                      thanks in advance
                      try this one
                      File Name: GD25LQ128D(1.8v)@SOIC8or.BIN
                      Block Dev Mode: Enabled
                      Enrollment Check: Disabled
                      • darckreign1984
                        • 260
                        Originally posted by Aries Molinar
                        try this one
                        The laptop doesn't show anything on the screen and doesn't start. It seems that the backup BIOS is corrupted, as it doesn't start anymore with it. Additionally, the external SSD lost some data, and it appears that I have more corrupted data inluding the bios.
                        The laptop starts with the BIOS from post 2.
                        • osman68i
                          • May 2015
                          • 360
                          • The Netherlands
                          it worked.
                          thanks in advance
                          your dump edited. you can compare and check the difference for the next time
                          • darckreign1984
                            • 260
                            thanks for you efort - buth the laptop dont start with this file.
                            no image no nothing.
                            only file taht work its from post 2. I cant remove enrolment, or deactivate developer
                            • osman68i
                              • May 2015
                              • 360
                              • The Netherlands
                              test with this bios
                              • darckreign1984
                                • 260
                                test with this bios
                                thanks, to bad its not working.
                                i dont have any explication.
                                • Aries Molinar
                                  • Jan 2024
                                  • 12
                                  • Philippines
                                  if you are using ch341a don't use test clip when backing up your BIOS it will end up backing up corrupted BIOS, it is best way is to desolder it and solder it on adapter
                                  • darckreign1984
                                    • 260
                                    i use tl866 II plus, and every time i remove the chip.
                                    must be something related to incompatibility bios and ec information. (i think that bios backup was corupted when ssd lost partition, i recovered some data, but i think some off them are corupted, included this bios)
                                    • darckreign1984
                                      • 260
                                      the laptop start only with this bios. I lost original bios - ssd data lost/corupted backup
                                      motherboard model ZBC
                                      DA0ZBCMBD0 REV
                                      QR CODE
                                      NBHKD110100
                                      34349617600
                                      thanks again
                                      • darckreign1984
                                        • 260
                                        DA0ZBCMBD0 REV
                                        QR CODE
                                        NBHKD110100
                                        34349617600
                                        thanks again
                                        With this bios laptop start, in developer mode, I can't remove MDM enrolment.
                                        • Boardview and Schematic Bot
                                          Acer Chromebook C933-C4NJ Chromebook 314 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook C933-C4NJ Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C933-C4NJ boardview and C933-C4NJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 03:40 AM
                                          Acer Chromebook C933-C795 Chromebook 314 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook C933-C795 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C933-C795 boardview and C933-C795 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 03:10 AM
                                          Acer Chromebook C933 -C9T6 Chromebook 314 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook C933 -C9T6 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C933 -C9T6 boardview and C933 -C9T6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 02:00 AM
                                          Acer Chromebook C933-C1DN Chromebook 314 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook C933-C1DN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C933-C1DN boardview and C933-C1DN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          Acer Chromebook C933 Chromebook 314 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook C933 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C933 boardview and C933 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Chromebook...
                                          09-07-2024, 01:30 AM
