Fujitsu Lifebook E756 vPro Bios Repair/Rebuild help
    I got a Fujitsu Siemens Lifebook E756 vPro with a corrupted Bios after flashing. Device wont start anymore, only Blackscreen.
    Dumped the Bios and attached it. Maybe someone can help me repair/rebuild the bios?
    Thanks in advance
    Try this file
      Thank you, but it is not working.
        ...and this ?
          Still the same, device not working.
            All right then, this is my last attempt.
            This file it's your dump fixed.
            If this is not working then probably it's not a bios content problem most likely a bad soldered pin or missing some little coil near bios chip,etc.
            Cheers!
              Mr.Nobody
              Thank you, Laptop is turning on and working👍
              • Mr.Nobody
                Mr.Nobody commented
                Editing a comment
                You're welcome!
              Hello i tried this dumped fixe from Mr. Nobody.
              But now i have blinking scroll Lock and after that shows screen.
              In Bios the product number is missing and the serial number.
              How can i change that?
              Please help me.
              Thank you
              BR
              Good afternoon ! I also have a Fujitsu E756 and I can't get into the BIOS. 3 incorrect passwords do not help. I do not know what to do
                Hello!
                Two E756s were brought back to the service center with the same fault. Black screen and the second and third LEDs in the row of the power button are flashing. Maybe they messed up the BIOS? Could you please check this file for me?
                MB: CP706745-01
                SN: DSEU046101
                Click image for larger version  Name:	dataurl520692.png Views:	2 Size:	359 Bytes ID:	3467557
