Hp Elitebook 820 G1 "warning!! machine is not in committed state"
  • darksideofthemoon
    • Nov 2012
    • 10
    • Italy
    I bought a new motherboard for my HP Elitebook 820 G1 but the warning error appears when I turn it on"
    I realized that since it was a virgin card, some data was missing... I took it from the notebook's plate and inserted it with a tool found online but the error remains. I can't find the BUILD ID (not even on the partsurfer site). Is there a way to recover it? I also have a bios backup from the previous card, could I recover it from there? Thanks and sorry for the bad English
    • 22119
    Re: Hp Elitebook 820 G1 "warning!! machine is not in committed state"
    Post your backup and the serial number
    • darksideofthemoon
      • Nov 2012
      • 10
      • Italy
      This is the bios dump of the previous broken motherboard and this is the serial number under the battery: 5CG44134JY
      and then BUILD ID also asks me for the FEATURE BYTE which I don't have
      Thanks for your help
      • rex98
        • Feb 2023
        • 1296
        • Mandaue CEBU, Philippines
        test that it works in mine without DMI data leave the EC just test that two mains.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12420
          FeatureByte : FBYTE#3X47676J6S6a757H7M7Q7W7j7saBaw.Nr;
          BUILDID : #13WWSBDW301#SABZ#DABZ;
          • darksideofthemoon
            • Nov 2012
            • 10
            • Italy
            Thank you for your help but unfortunately when entering these values I get an error
            [IMG][/IMG]
            • darksideofthemoon
              • Nov 2012
              • 10
              • Italy
              So do I have to program the bios of the new motherboard using one of the two attached files?
              I don't want this operation to permanently compromise the functioning of the notebook, considering that now the only problem is the writing in question.
              • darksideofthemoon
                • Nov 2012
                • 10
                • Italy
                I used main tested ok.zip and solved the problem. I really don't know how to thank you.
                • sc84647
                  HP Elitebook 840 G3 - "Machine is not in committed state"
                  by sc84647
                  Hi
                  I have an EliteBook 840 G3 that boots with "Machine is not in committed state!", the system info is correct when displayed in the BIOS screen:
                  Serial Number : 5CG6481F5D
                  Product Number : L3C65AV
                  Description : HP EliteBook 840 G3
                  I've tried using the BiosConfigUtility.exe from HP BCU (SP143621) which says MPM is in Lock state, and if I try changing that using that tool I get:
                  <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access Denied" returnCode="6">
                  <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
                  02-11-2024, 08:27 AM
                • pcproffsen
                  Elitebook 850 G1 "machine is not in committed state"
                  by pcproffsen
                  What are the Brands about?
                  Which one is for what PC model?
                  I have a Elitebook 850 G1, with the problem "machine is not in committed state" showing at boot.
                  But I can login to Bios, and everything looks ok there. And no hardware is changed.
                  I also updated to latest Bios version.
                  So I just dont understand why this message shows, how can I get rid of it?...
                  03-30-2023, 11:43 AM
                  HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-07-2024, 05:50 AM
