PLEASE UNLOCK THIS FILE
HP Elite x360 830 G9 2-in-1 bios unlock
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Off topic, this thread is for the 830 G9 2-in-1 , not the 1040 G9 .Post your request in the 1040 G9 2-in-1 thread --> https://www.badcaps.net/forum/troubl...-bios-passwordComment
HI NEED HELP UNLOKING BIOS ELITEBOOK 830 G9 6050A3316601-MB-A01Attached Filesif you find these attachements useful please consider making a small donation to the site
how can get the patcher for unlock bios ?
in first boot press f10, apply factory defaults and exit, after restart press f10 again go-to security setting reset security settings to default. then use BCU.
Serial Number: 5CG3021WH1
Product Number: 6W5Y3UC#ABA
CT Number: PMYEK00WBHL100
Description: HP Elite x360 830 13 inch G9
build_id: 22WWWPBZ601#SABA#DABA
Feature Byte: 476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6fPfXgSguhKjhk8mEn7nVngpFpVpWpnpqprqjqz.8f
MAC Address: 7C-4D-8F-33-AF-1FโComment
x360 830 g9 lock please unlock
SN 5CG3126G9NAttached Filesif you find these attachements useful please consider making a small donation to the site
try
in first boot press f10, apply factory defaults and exit, then use BCU.
Serial Number: 5CG3126G9N
Product #/SKU: 479Y5AV
CT Number: PMYEK00WBHV1SK
BuildID: 22WWWPBT601#SABD#DABD
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVcAd6dpdqeMfAfPfXgSguhKjhk8mEmVn7nVngpTpWpqqjqz.E8
MAC Address : E0:73:E7:5E:E0:9AโAttached Filesif you find these attachements useful please consider making a small donation to the site
HP Elite x360 830 13 inch G9 2-in-1 Notebook PC
CT Numbe_6MBNL0AGWHE2MN
Serial_5CG3126G9N
Product_479Y5AV
Fearture byte_476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVcAd6dpdqeMfAfPfXgSguhKjhk8mEmVn7nVngpTpWpqqjqz.E8
Build Id_22WWWPBT601#SABD#DABD
โต
โhttps://www.badcaps.net/donateComment
Hello, gentlemans! Need your help with this file.There is a forgotten password in the BIOS. Could someone try to remove the password?
Thank you very much!
NAME: HP Elitebook x360 830 G9 2-in-1
PRODUCT NUM.: 479Y8AV
SERIAL NUM.: 5CG33322CG
HP Elite X360 830 G9 2-in-1
SN: 5CG3093WYG
Bios ver: U70 Ver.0105.00 12/30/2022
what tool do you use for patch?
try
MAC Address : E0:73:E7:5E:E0:9AComment
My device does not have an original BIOS. I tried BIOS version #7 and the device works perfectly, but it takes 1 minute to boot up. Please fix the BIOS.
6050A3316601-MB-A01
S,N 5CG2287PYK
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
by cqdlyHello Need bios unlock for hp Elite x360 830 G10 2-in-1 SN:5CG33350LJ thank's in advanced...
Channel: BIOS Requests ONLY!
by whelanm87Hi everyone,
Iโm working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. Iโll be posting my own backups for reference and comparison.
๐ System Details- Model: HP Envy x360 15-fe0053dx
- Product Number: 7HVO3UA#ABA
- Build ID: 23WW2GQZ6D
- Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
- Motherboard SPS: N30979-ABA
- LCD SPS: N49271-601
- Date Code: 172380
- Keyboard Type: 0
- Feature Byte:
3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
hZnp.praepq0Md4qkdf
๐ง Chip Info- Main BIOS chip: Winbond W25Q128JVSQ
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
by Andrew BowerHi,
I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....-
- Loading...
