hello help remove bios password
asus fx506hc DA0NJJMBAG0 REV.G bios password reset
Tags: None
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: asus fx506hc DA0NJJMBAG0 REV.G bios password reset
this is the dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is,be specific - Black screen,no boot,running slow,password.
Do NOT post "clean me","clear bios","clean bios","bios need" or other such terms
.Comment
fx506hc DA0NJJMBAG0 REV.G I added the original bios, bios password is required. can you help me? I tried different bios but it didn't work.
Send to you , or try Pass : burak52Attached Filesif you find these attachements useful please consider making a small donation to the site
I have an Asus FX506HC SN:R7NRCX001634274 MB CODE DA0NJJMBAG0 REV: G WITH BIOS PASSWORD. It has also Admin and User password and I belive boot password. I managed to find out the admin one but cannot find the user and boot one. i am atachingthe original dump, maybe someone can help me identify. thank you in advance.
prima e (1st): gabi20Hello,
a 2a (2nd): marasergiu50ā----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi there
please help
bios is locked need password
please give me the password of bios bios file or some other solution. many many thanks.
Laptop ASUS FX506HC
Serial N7NRCX05Z664297
Motherboard DA0NJJMBAG0Attached Filesif you find these attachements useful please consider making a small donation to the site
please try this one its a fresh from website and clean me region, give feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
please help
laptop asus model fx506hc-ub51
sn n4nrcx01096214c
cn: 95yj
mfd 2022-04
mothboard DA0NJJMBAG0 REV GLast edited by Lisa Laflam; 12-21-2024, 08:56 PM.Comment
Every donation made will go towards server fees and maintenance costs.Comment
hi i need password for this bios please
DA0NJJMBAG0 REV G
fx506 HC
by ch.waHI,
I have a problem with the BIOS password for the HP ProOne 440 G9 (AIO). Once I want to enter the BIOS a password is requested (see screenshot) and I am a little unsure if it would be smart to try a wrong password three times (as some people mentioned online) to get a code - I don't want to block the whole system (not sure if that could happen?!). According to other sources a reset is (maybe) not even possible for this model.
Any ideas if this may work? Hope someone could help.
Thanks for your time!
Chris1 Photo-
10-29-2025, 01:28 PM -
by namelemen32I have HP Compaq dx6120 i need to reset my bios password.I tried some methods like using CMOS button but it did not work so my last chance is using SMC.bin.
Serial Number : SAA62408WR
P/N: EC893ES#ABV-
Hello,ššš
I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
š§ Model: HP ProBook 11 G2
š¦ Serial Number: 8CG72478MY
š UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
š BIOS Status: Locked with password
The laptop is no longer under warranty and HP refused to help me.
Iām looking for a custom SMC.bin file.
I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
Thanks a lot for your help!ššš...-
Channel: BIOS Requests ONLY!
by lefou486Hello,
I made a big mistake
I put a password for BIOS & i don't find it
I use a random password generator & I neted the password before put into the bios
Everything works OK until i want to change an option in my BIOS
password is wrong
I don't understand
How reset this password ?
Thanks for your help-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
