Asus TUF F15 (2022) FX507ZC4
  • djesoric
    • Apr 2010
    • 27
    • Philippines
    #61
    somebody please help! the laptop has no display.
    Asus TUF FX507Z
    serial Number: R6NRCX04H22825A
    BOARD #: DANJLMB2AA0 REV:A
      • 21389
      Asus TUF FX507Z
      If you can see a QR code on the motherboard scan it and post what it says or take a picture of it.
      • djesoric
        • Apr 2010
        • 27
        • Philippines
        #63
        here is the picture and the QR code picture.
        • Alserg
          • Jul 2025
          • 4
          • Serbia
          #64
          Hello! Can anybody help? The laptop does not start after incorrect BIOS flashing. Orange LED blinks when charger is connected. Need bios binary file.
          Asus FX507ZC4-HN009
          SN : S1NRCX09L70405H
          CN : E3YD
          MFD : 2024-01
          MAINBOARD : DANJLFMBAB0 REV : B
            • 21389
            Attached is your FZ507ZC4 bios (as in the QR code) , with your DMI. The bios is from the post above https://www.badcaps.net/forum/troubl...02#post3683602 ,it`s an F1 Asus Service bios.
            DMI offsets for anyone else who can use a hex editor - 10C1000 - 10C8FFF
              • 21389
              Asus FX507ZC4-HN009
              CN : E3YD
              MFD : 2024-01
              Read the posts above, if your QR code says the model is FX507ZC4 you can use the F1 bios, and if you can use a hex editor you can copy the DMI from your backup, if you have one, to the new bios.
              • woofer
                • Sep 2017
                • 4
                • privet
                #67
                здравствуйте! помогите создать правильный bios . черный экран
                English ! Hello! Help me create the correct bios. Black screen
                Asus FX507ZC4-HN144
                SN : S1NRCX09H473050
                CN :3KKF
                MFD : 2024-01
              • Alserg
                • Jul 2025
                • 4
                • Serbia
                #68
                Thanks.
                QR code says: QCCNJL5JE40401252, S104NRCX00D61XMB, FX507ZC4, 60NR0GW0-MB1010, 107C6103DAA2
                I flashed FX507ZC4F1.307 (in this file DMI segment 10C1000 - 10C8FFF clear) via ch341, soft - AsProgrammer, before flashing i erase chip GigaDevice 25R256EYIS. But it doesn't work - as before laptop does not start and orange LED blinks when charger is connected. I edited FX507ZC4F1.bin DMI segment with
                CCNJL5JE40401252 0307A
                S1NRCX09L70405H
                90NR0GW1-M000P0
                S104NRCX00D61XMB
                2024-02-01 19:05:07.111
                This data i found in the file that was originally read. When i flashed this originally file laptop does not work at all - not start, not orange led blinks. I think originally file readed not correctly (by soft CH341A ver1.34). Edited FX507ZC4F1.bin also not working. Can you help me? Thanks and sorry for bad english)
                  • 21389
                  If it`s not working with the F1 bios FX507ZC4F1.307 even without the DMI then there`s some other problem. You will have to find a schematic/boardview/repair-guide and check hardware
                  • woofer
                    • Sep 2017
                    • 4
                    • privet
                    #70
                    hi! engineering bios works! image is there
                    please enter DMI
                    • Alserg
                      • Jul 2025
                      • 4
                      • Serbia
                      #71
                      I think so too. The charge controller may be damaged. I took it to the service center. Thank you
                      • Alserg
                        • Jul 2025
                        • 4
                        • Serbia
                        #72
                        please enter DMI
                        повезло) а у меня похоже вышел из строя контроллер заряда..
                        English: lucky) and it looks like my charge controller is broken..
                          • 21389
                          please enter DMI
                          Your bios + DMI
                          • woofer
                            • Sep 2017
                            • 4
                            • privet
                            #74
                            Your bios + DMI
                            Thank you very much! Everything works.
                            • djesoric
                              • Apr 2010
                              • 27
                              • Philippines
                              #75
                              thank you so much! The laptop is now working well.
                              • Smeek
                                • Sep 2021
                                • 63
                                • România
                                #76
                                hi, pleace rebuild my bios, the GPU appers in bios, when the windows logo coming the GPU stops work, no more voltage on GPU coils
                                here is the Original bios:
                                Model: FX507ZC4-HN061
                                SN: R7NRCX06C58429G
                                CN:HTG3
                                • bogdan039
                                  • Dec 2018
                                  • 61
                                  • Romania
                                  #77
                                  hello.
                                  ASUS TUF 15 model FX507Z
                                  FX507ZC4-HN060
                                  SN: NCNRCX04J399508
                                  CN:ALD2
                                  mb : DANJLFMBAB0 REV: B
                                  the original bios has no video(black screen).
                                  with clean bios #3 from first page it works well but wrong serial number(SSN123456789012345).
                                  please fix my original bios, no video.
                                  thank you in advance.
                                  • Khoja
                                    • Jul 2016
                                    • 33
                                    • Узбекистан
                                    #78
                                    Hello friends,
                                    I need the main BIOS and EC BIOS for this laptop. Before I got it, someone had already flashed it, and now the laptop doesn’t turn on. When I read the chips with a programmer, I found no data in either the BIOS or EC chip.
                                    Platform: DANJLMB2AA0 REV: A
                                    Model: FX507ZC4-HN009
                                    SN: R5NRCX06K104219
                                    CN: 8N0K 12M
                                    MFD: 2023-05
                                      • 21389
                                      Originally posted by Khoja
                                      Hello friends,
                                      SN: R5NRCX06K104219
                                      CN: 8N0K 12M
                                      MFD: 2023-05
                                      Scan the QR code on the motherboard, if the model is FZ507ZC4 use this bios https://www.badcaps.net/forum/troubl...92#post3692292
                                      I don`t know if the EC will flash itself from the bios but try.
                                        ASUS TUF Gaming FX507ZC4-HN018 Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX507ZC4-HN018 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX507ZC4-HN018 boardview and FX507ZC4-HN018 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-07-2024, 06:40 AM
                                        ASUS TUF Gaming FX507ZC4-HN018W Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX507ZC4-HN018W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX507ZC4-HN018W boardview and FX507ZC4-HN018W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        ASUS TUF Gaming FX507ZC4-HN009 Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX507ZC4-HN009 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX507ZC4-HN009 boardview and FX507ZC4-HN009 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-07-2024, 06:38 AM
                                        ASUS TUF Gaming FX507ZC4-HN011 Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX507ZC4-HN011 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX507ZC4-HN011 boardview and FX507ZC4-HN011 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        ASUS TUF Gaming FX507ZC4-HN041W Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX507ZC4-HN041W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX507ZC4-HN041W boardview and FX507ZC4-HN041W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 06:31 AM
