i need unlock file elitebook 845 g9
  • doctor2022
    • Jul 2023
    • 23
    • korea
    pls unlock help me.
  • volinakis
    • Jan 2021
    • 2728
    • N/A
    Re: i need unlock file elitebook 845 g9
    Originally posted by doctor2022
    pls unlock help me.
    At 1st boot press F10 and reset bios to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the bottom cover. Or extract DMI from your bios dump:
    Feature Byte: 6J6S6b7B7H7M7Q7W7m7s8uaBaEapaqatauawbUbhd7dXfPgSgujBk8mEn7nWngpDpFpJpnpqprqjqz.B4 (no spaces)
    Serial: 5CG2208SL7
    SKU: 6K5B5PC#AB2
    Build ID: 22WWLHAZ601#SAB2#DAB2
    Board CT: PPZGQ00WBGM0A1
    Name: HP EliteBook 845 G9
    Save and use BCU to exit MPM mode or restart laptop how many times counter shows.
    • doctor2022
      • Jul 2023
      • 23
      • korea
      Serial: 5CG2208SL7
      SKU: 6K5B5PC#AB2
      working file thanks Bro so much.
      • souaqi01
        • Dec 2015
        • 87
        • Maroc
        plz unlock this fil bios 845 g9
        • volinakis
          • Jan 2021
          • 2728
          • N/A
          serial number? Read RULES.
          • kumquatscurrant
            • Jan 2024
            • 3
            Hi folks,
            I have an 845 G9 that also has a BIOS password that I've forgotten. I've dumped the contents of the mx25l25673gz4i-08g above the RAM slot and have attached the binary. Would someone be able to help be remove the password?
            System details:
            System BIOS: U82 Ver. 01.07.00 10/05/2023
            Serial Number: 5CG3333DH3
            SKU Number: 544M0AV
            UUID FC5B65FD-2955-4873-83BD-649ACC7B2663
            Feature Byte:476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhc
            AfPgSguhKjhk8mEn7nWngpDpFpnpqprqjqz.HD
            System board ID: 8990
            System board CT number PPZGT00WBIE0CM
            Thank you!
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Originally posted by kumquatscurrant
              Hi folks,
              Read this carefully:
              [Hint] You can use HP BCU to get and save the config file before flashing the unlocked bios.
              After unlocking, you can use saved config file to get all the information back, to avoid all the "fun" of manually entering the data
              Unlocked dump:
              Become a Badcaps supporter
              Thanks to all supporters.
              • samirinfo
                • Mar 2020
                • 51
                • oran
                j'ai besoin de déverrouiller le fichier Elitebook 845 G9
                SN : 5CG316453S
                PROD ID : 544L9AV
                s'il vous plaît débloquer, aidez-moi.
                I need to unlock Elitebook 845 G9 file
                SN : 5CG316453S
                PROD ID : 544L9AV
                please unblock, help me.​
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                here you go
                At 1st boot press F10 and RESET BIOS to factory defaults, save​
                • samirinfo
                  • Mar 2020
                  • 51
                  • oran
                  THANK YOU . SIR
                  • ICloud
                    • Jan 2021
                    • 26
                    • România
                    Hello. Hp ELITEBOOK 845 G9 amd. Bios lock.
                    sn- 5CG3210MSS
                    Can anyone help me? Thanks!
                    p.s> size is compress
                  • leo037_2023
                    DEMIGOD OF BIOS
                    • Oct 2023
                    • 63
                    • Buenos Aires - Argentina
                    your backup file its bad.
                    • ICloud
                      • Jan 2021
                      • 26
                      • România
                      What is the problem?
                      • leo037_2023
                        DEMIGOD OF BIOS
                        • Oct 2023
                        • 63
                        the backup file its corrupt check again
                        • andrew25
                          • Feb 2016
                          • 221
                          • Malawi
                          Can anybody help unlocking my dump, its HP ELITEBOOK 845 G9 AMD
                          S/N : 5CG2462KWL
                          ProdID: 544M1AV
                          I attached my EC dump
                          • danito
                            • Jun 2016
                            • 899
                            • Romania
                            S/N : 5CG2462KWL
                            ProdID: 544M1AV
                            it is not in EC.
                            • andrew25
                              • Feb 2016
                              • 221
                              • Malawi
                              Originally posted by danito
                              it is not in EC.
                              here is the other dump
                              • danito
                                • Jun 2016
                                • 899
                                • Romania
                                SerialNumber:5CG2462KWL
                                ProductConfigurationID:544M1AV
                                Board CT Number:PPZHE00WBHC0S8
                                Name:HP EliteBook
                                ProductName:HP EliteBook 845 14 inch G9 Notebook PC
                                FeatureByte:476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhdpdqfPfXgSguhKj4jhk8mEn7nWngpDpqqjqz.YT
                                BuildID:22WWLHBT603#SBH5#DBH5
                                NetWork Mac Address :CA-84-E0-C1-11-38​
                                • andrew25
                                  • Feb 2016
                                  • 221
                                  • Malawi
                                  Thank you, it all worked perfect
                                  • farouk_1994
                                    • Mar 2021
                                    • 390
                                    • algeria
                                    help please unlock my dump HP ELITEBOOK 845 G9
                                    S/N : 5CG3304BS1​
                                      HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 05:50 AM
                                      HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 05:20 AM
