Hp elitebook 840 g9
    Originally posted by maobuff View Post
    Can someone unlock bios for HP elitebook 840 g9?
    SN# 5CG23634TL
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU. you can permanently disable Absolute lock in BCU.
    here's your DMI:
    Serial Number: 5CG23634TL
    Product #/SKU: 6Z4A9UP#ABA
    CT Number: PQSPN00WBH31K5
    Description: HP EliteBook 840 14 inch G9
    BuildID: 22WWWPAT602#SABA#DABA
    Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEmwn7nVngpDpVpqqjqz.Eg
    MAC Address : 38:CA:84:4E:F9:E1
      here's your DMI:
      Hi. First boot f10 and I'm able to reset to factory defaults. on second boot I'm unable to enter bios. It always freeze on entering setup and restart after few seconds. Bios is still locked.
        try again
          try again
          Same, after restoring factory defaults next boot always fails.
            Try
            1. Flash Patched File
            2. in First BOOT got to SETUP in MAIN Tab Restore Factory Defaults
            3. Save and Exit
            4. Flash back Original Bios BIN File
              Originally posted by danito View Post
              Try
              3. Save and Exit
              Can I just solder wires to bios chip to save time? ofc I will remove bios battery and main battery.
                I don't know, yes, remove the batteries.
                  Try
                  3. Save and Exit
                  What I did:
                  1)desoldered bios chip
                  2)flashed bios with verification
                  3)put laptop together(connecting everything)
                  4) after connecting bios battery and main battery laptop turned on with f5 and f8 light up and fanspin, then it powered off, then again f5 and f8 light.
                  5) on second reboot backlight turned on and Im able to enter bios, in main tab I selected reset to manufactures default and exit
                  6) laptop turned on with f5 and f8 lights, after 1-2min turned off
                  7) removed motherboard and desoldered bios chip
                  8) flashed my original dump and soldered it back
                  9) assembled laptop and again after pluging main battery it turned on with f5 and f8 lights
                  10) after 2 reboots again screen backlight turned on and i was able to enter bios(f10) and its still locked
                  I have assumption that f5 and f8 it is some sort of memory training because its an ddr5.
                    Please remove BIOS Administrator Password
                    hp Elitebook 840 G9​
                    6050A3417601 MB A01
                    SN 5CG30614P3
                      hp Elitebook 840 G9
                      6050A3417601 MB A01
                      SN 5CG30614P3
                      here's your DMI:
                      Serial Number: 5CG30614P3
                      Product #/SKU: 6B4Y0AV
                      CT Number: PQSPP00WBHO2JN
                      BuildID: 22WWWPAD301#SABD#DABD
                      Feature Byte: 3Y6E6J6S6a7H7M7R7W7d7j7m7saEawbUbhcAfAfPguhKhkjhk8m6n7nVngpFpTqjqz.2e
                        [QUOTE=rex98;n3317671]
                        here's your DMI:
                        lot of thanks worked 100%
                          Por favor elimine la contraseña de administrador del BIOS
                          hp Elitebook 840 G9
                          6050A3417601 MB A01
                          SN 5CG3027M3C
                          Archivos adjuntos
                            hp Elitebook 840 G9
                            6050A3417601 MB A01
                            SN 5CG3027M3C
                            Archivos adjuntos
                            here's your DMI:
                            Serial Number: 5CG3027M3C
                            Product #/SKU: 6W029UP#ABA
                            CT Number: PQSPQ00WBHLER9
                            BuildID: 22WWWPBZ601#SABA#DABA
                            Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPgSguhKjhk8mEn7nVngpFpVpnpqprqjqz.dy
                            MAC Address : 7C:4D:8F:37:61:FD
                              here's your DMI:
                              worked 100% thanks
                                Hello! Can you help me to unlock bios?
                                Model: 840 G9
                                SN: 5CG3133N35
                                  Model: 840 G9
                                  SN: 5CG3133N35
                                  Can someone help me?
                                    Serial Number: 5CG3133N35
                                    try this than replay
                                      Your bios the same as a locked
                                        try
                                          Model: ELITEBOOK 860 G9
                                          SN 5CG3063R73
                                          Off topic.Don`t hijack threads when the model number is different. You have already asked for the bios once https://www.badcaps.net/forum/troubl...g9#post3331962
