IdeaPad 5 15ALC05 bios please!
  • peste
    replied
    Originally posted by Maniackk
    IdeePad 5 15ALC05 bios please!
    The LEDs are on and there is a black screen.
    I tried to upload the bios from thread #5 but no effect. I have a request for the correct BIOS with my DMI. Original ripped bios attached.โ€‹
    Lenovo Ideapad 5 15ALC05 , HS553 MN-D701 Rev 1.0 Rayzen 7 Black Screen.
    S/N: PF3EXDCR
    MTM: 82LN00REPB
    you have everything you need at post #55...
  • Maniackk
    replied
    S/N: PF3EXDCR
    MTM: 82LN00REPB
  • peste
    replied
    Originally posted by thesumate
    ok, I edited that file now and pasted all that unreadable decrypted stuff from my backup to the virgin bios. Now I can upload it to my bios chip right? Do I have to click on that in my asprogrammer?
    And I just copied everything in a range from 1000 to 2FF0 from my bios to the virgin bios. The start on my new created bios is just empty FF everywhere is that right?
    yes, you can write the bios chip with the newly edited content..I haven't used that program and CH341A..I don't know to tell you anything about it..
  • thesumate
    replied
    And I just copied everything in a range from 1000 to 2FF0 from my bios to the virgin bios. The start (0 - 1000) on my new created bios is just empty FF everywhere is that right?
  • peste
    replied
    Ok, so I select the hex values from 00001000 to 0002FF0 (there is no 2FFF) and copy all that in the file from your post#54 (h2cn31ww.rar) even though I can't read anything there right?
    the text says this:
    "LENVk๏ฟฝ๏ฟฝ๏ฟฝ๏ฟฝ๏ฟฝ๏ฟฝ๏ฟฝ ยฆOโ€ Mm*gยKลก@รดร‘ลฝรรจ \^ร‹`_Eยญฦ’โ€˜-ยขJ
    8<:><0=?9;1;:\^ร‹`_Eยญฦ’โ€˜-ยขJ *รง~รกยฎรขโ€ฐรฆ1รบยขยกCร8รขรธยด4โ€š Cยฐยฃย*ยซร‹{ \^ร‹`_Eยญฦ’โ€˜-ยขJ YO;SDLHJ\^ร‹`_Eยญฦ’โ€˜-ยขJ Z\^ร‹`_Eยญฦ’โ€˜-ยขJ @mlhYhm)<)8<HEJ9<\^ร‹`_Eยญฦ’โ€˜-ยขJโ€‹
    well, there's nothing to read there, because it's empty, the bios being virgin...yes, you have to fill that empty space..
  • thesumate
    replied
    the text says this:
  • peste
    replied
    I got the programmer and read the bios of my 15-alc05 now. My Bios chip is called "74m12jwsiq" but asprogrammer automatically suggested "W25Q128FW". What do I have to do now? How do I add that DMI info and what is this? is it necessary? Here is my bios backup (i have packed two files into the folder on one I just clicked save and on the other i added .bin when i saved it)
    try the bios from post #55, there is also the interval where the DMI information is found, use the HxD program (you can find it for free), enter both bios into the program, select the interval in both bios and pass the interval from your bios to the interval from the bios from postl#55 (copy-paste), that's all..
  • thesumate
    replied
  • danito
    replied
    Originally posted by StormCrow
    Hi all.
    Got a 15-ALC05 here with a black screen / power light. BIOS dump attached. S/N is PF2YAA43
    I'm struggling to transfer the DMI data across, have tried a couple of the attached BIN files from this post but no difference.
    Could someone kindly provide me an edited file (and ideally the location of the DMI data - I'm reading it's 1000 - 2FFF but not sure if that's accurate for this dump?)
    Thanks in advance
    try
  • StormCrow
    replied
    Hi all.
    Thanks in advance
  • thesumate
    replied
    Ok, perfect! I just wanted to make sure it's working for my chip before I buy something. This programmer is fine? https://www.amazon.de/EEPROM-Program...ustomerReviews
    And I can basically use any ch341a programmer software right? Or should I use a specific one?
    replied
    ok, if i select this chip "W25Q128FW". I can read and write without issues event tough my chip is called "74m12jwsiq" ? So I can write the bios from lenovo website right on it and then it should work?
    Make a backup and post it here.
  • thesumate
    replied
    commented on 's reply
    Choose W25Q128FW manually from the chip list
  • thesumate
    replied
    I downloaded multiple programs now but I can't find my chip in any of them. What do I have to select instead now? What could go wrong if I select another chip so read another chip?
  • peste
    replied
    Alright thank you very much!!
    "get a chip from the database equivalent to what you have in your laptop", so do I have to look for a chip that's available in the software with the same properties as here:
    https://www.winbond.com/hq/product/c...artNo=W74M12JW
    yes..yes.. but try the two programs, maybe you have the chip there..
  • thesumate
    replied
  • peste
    replied
    Ok perfect. But I can't find this chip in the software for the spi programmer. This chip isn't listed there. What do to? Or do I have to get another program?
    use one of these programs.. if you can't find it, get a chip from the database equivalent to what you have in your laptop..
    don't forget to make a copy of the original bios before writing with new content..
    https://www.badcaps.net/forum/showpo...6&postcount=10
    https://www.badcaps.net/forum/showpo...postcount=7โ€‹
  • thesumate
    replied
  • peste
    replied
    Ok, so on the front of the mb there is nothing but this one chip that looks like it could be a bios chip. Since this is all over this laptop model, does anyone know where its located? The back of the motherboard also has some sort of shield on it and I dont really want to unscrew it and take that shield off.
    EDIT:
    I removed the board now and also looked on the underside under the shield thingy for possible bios chips but there weren't any chips at all. The only one that looks like it is the one from earlier called "Windbond 74M12JWSIQ 2112"
    Winbond 74M12JWSIQ is the bios chip...
  • macabook
    ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
    by macabook
    Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
    ๐Ÿงฉ Initial Issue
    07-24-2025, 02:17 PM
    Lenovo IdeaPad 5 15ALC05 Notebook 5 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad 5 15ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ALC05 boardview and 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
    09-07-2024, 04:30 AM
    Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
  • jendkkd jeje
    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
    by jendkkd jeje
    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
    10-11-2024, 03:12 PM
