New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
bios extracted from the HP site update, the laptop has four bios variants...
Choose the right one , or upload your bios dump here as you should've done already, along with the serial number and issue description, so we can be able to help you to choose.
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters. ----------------------------------------------------------------------------------------------------------------------------------------------------------
In the laptop, the multi-controller failed, after replacement and firmware, the laptop consumes 0.033 A. The 0.88 V power supply of the chipset is present, but the power supply of the processor cores is absent.
I will try to flash it tomorrow. Thank you very much
You're welcome. Good luck.
i' cant find this EPV51 LA-G078P motherboard schematic and Mosfet Burned its like dual channel mosfet. please tell what is that part number if you know....
dear all ..
i have EPV51 LA-G078P MB ...the cpu is getting too hot when powered on but no display the capacitors above on processor are shorted to GND.
kindly help whether i can remove the capacitors or not ..
