Lenovo Ideapad 5 15ARE05 random freeze
  • EsIstSimon
    • Feb 2022
    • 4
    Hi there,
    i have a Lenovo Ideapad 5 15ARE05 that will freeze randomly.
    Sometimes it wont even post, sometimes i can use it for a couple seconds or minutes before it completely freezes.
    Sometimes the screen freezes, but still displays the last frame, sometimes (pretty rare) the screen goes black
    It does not matter what i do. Installing windows, starting Fedora or just sitting in the bios. After some time it will freeze.
    When the freeze occurs, the laptop draws a pretty constant wattage (it will just stay on the value that it draws, when it locks up +- couple hundred mw) and will never return to a functional state.
    It does not seem to matter if its a cold boot or if it power cycled a few times.
    When it posts (screen comes on and Lenovo Logo appears) and i shut it down right away, it works for the next boots without an issue.
    When it has frozen once, it takes some time and/or trys to get it back to a working state.
    In this no post state, starting the laptop will turn on the keyboard backlight and fan for 2-3 seconds, both then turn off and the laptop draws ~14watts.
    I can still turn on/off the keyboard backlight, but Capslock / Fn lock wont work. The cpu will heat up and the fan will come on from time to time.
    What i have tried so far:
    - Remove battery and CMOS and perform a static discharge
    - Remove everything connected to the board
    - Reflash Bios. I extracted it from Lenovo updater and trimmed the file according to the original backed up bios. I flashed it with a CH341A, while the BIOS chip was still on the board. I read in one or two threads that people recommend flashing the bios out of circuit, do you think i should give this a try?
    Also i have not transfered the DMI to the new BIOS yet, as i wanted to test it first, but this should not be the problem here, right?
    The board is completely clean and since it will work from time to time, i dont think anything has blown.
    My best guess would be a failing APU, but since i am pretty new to the world of electronics repair, i kind of lack the experience to be sure about that.
    I was thinking about a mild reflow of the cpu, but i am not sure it this will result in anything, since it does not matter if the cpu is cold or not.
    Another guess would be a failing memory chip.
    Maybe you guys have another idea and can nudge me in the right direction
    Thanks a lot!
  • EsIstSimon
    • Feb 2022
    • 4
    Re: Lenovo Ideapad 5 15ARE05 random freeze
    Since i got no response here, i just went for my best guess and did a reflow of the cpu.
    Machine works like a charm (at least for now) =)
    Maybe this information will help someone in the future.
    Cheers
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Reflow of the SOC wont work beyond a couple of days. You need to reball it.
      • Corentinrhr
        • Jul 2024
        • France
        Hello, I have exactly the same problem with the same laptop model. Does the reflow of your CPU still work to this day? How did you do it?
        • javieromex
          • Apr 2016
          • 76
          • México
          I have same issue with same model. Board: NM-C811. Do you know how to remove the black epoxy? Otherwise I will try with reflow
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Dont even attempt a reflow without you being able to remove the black glue. Else situation will worsen further. Simplle physics-on heat,element will expand and the glue wont allow it to expand-so will result in damage to SOC.
            Removing that glue is a nightmare.Often the PCB pads gets damaged.
            • ictc
              • May 2015
              • 46
              • Italy
              I'ma having the same issue with an IdeaPad ryzen 5, I thought could have been the onboard ram failing but that should not explain why after crash the CPU temperature suddenly rise up of about 5 degrees. I also tried replacing the bios with no luck at all. I'll try the reflow and if anything changes in better I'll manage to perform a complete reballing. Do you have experienced other random freeze after reflow?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Lenovo use low temp melting solder and its not that easy to succesfully desolder the cpu 'coz of black glue as u cant go with very high temp.
                I still struggle with SOC reball on lenovo.. Btw, i hate BGA work anyway.
                • ictc
                  • May 2015
                  • 46
                  • Italy
                  I managed to desolder the CPU with only a couple of not connected pads ripped off. I found out that the very thin PCB thickness allow an easy and fast desolder compared to other thicker motherboard. The dark glue was not actually a problem. My only problem now is finding the right stencil to reball the CPU. I also caused some solder mask to peel off during desoldering and I need to reapply the green oll entirely without a proper stencil...that would be the most annoying part so far.
                    Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 05:20 AM
                    Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    09-07-2024, 05:00 AM
                    Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
