dag31amb6d0 no image
  • marcelofct
    • May 2019
    • 122
    • chile
    Hello, friends, i need your help,
    I have a hp dag31amb6d0 rev d motherboard, when connected to the power source, it turns on, but njo gives me an image, install a bios from this website, check and the fan does not turn, nothing
    In summary :
    I have light on the power jack, 3v on the power button
    I do not have 3v always nor 5v always, i turn on the laptop with the start button but i do not have amperage consumption for me it is very strange, this happened after they tried to change the hard drive for an ssd then it did not turn on anymore
    I leave the schematic in case someone helps me solve this dilemma
  • mon2
    • Dec 2019
    • 14673
    Re: dag31amb6d0 no image
    Hi. See attached.
    Meter in DC volts (20V or higher is ok) scale.
    Measure the voltage to ground of each of the requested 3 points.
    Red probe to point to test; black probe to ground ((Brooke) shield(s) is ok).
    Post each measurement.
    • marcelofct
      • May 2019
      • 122
      • chile
      Originally posted by mon2
      Hi. See attached.
      1.- 19V
      2.- 25V
      3.- 6V
      thank you !!
      • mon2
        • Dec 2019
        • 14673
        These are good readings. Meter in resistance mode. Remove all power. Check the resistance to ground of each of the coils linked to the always on rails. Maybe a shorted cap on the rail.
        If not low resistance, check the voltage to ground of the EN pins on the always on regulator. Post all readings.
        • marcelofct
          • May 2019
          • 122
          • chile
          PL29: +5vs5_s : 8.3 kohm
          PL30: +3V3s5_s : 12.7 kohm
          It is the only thing I found.
          since when connecting the charger I do not have voltages in the inductors mentioned only in the power button 3.3V
          EN PINS
          PU19: EN1=3.3V EN2=4.3V
          PU18: EN= 3.3
          • mon2
            • Dec 2019
            • 14673
            See attached,
            1) the resistance readings do not show a short circuit
            2) are the circled parts a solder blob on each point ? If yes, remove the solder blobs so we can focus on the regulator voltage for each only.
            That is, the voltage at the inductor should produce the respective voltage without a load.
            3) the enable pins are good and this means the upstream logic is requesting for these regulators to enable.
            From past reviews, these regulators are wimpy and they do blow often. You may have to replace each if you see the VIN voltage to be ok.
            Update - confirm the voltage to ground of each LDO pin on these regulators as well.
            Confirm each measurement.
            • marcelofct
              • May 2019
              • 122
              • chile
              See attached,
              nope , no problem with that
              i hope nop
              PU18: pin8=19V pin2=0V
              PU19: pin8=19V pin2=0v
              Now while I was taking the measurements, PU19 got hot. I will remove it to make measurements.
              • mon2
                • Dec 2019
                • 14673
                if hot with no load = defective regulator. The parts are not expensive if bought from Aliexpress. You may even have a local shop that has them in stock if they do similar repairs.
                You must, repeat must purchase the same part # as shown in the schematics.
                SY8208B ; PU19 the suffix is important and defines how the EN pins function.
                Here is a shop we have used a number of times without issues:
                https://www.aliexpress.com/item/3264...d=CxSH5Ss8VOp9
                SY8208C ; PU18 the suffix is important and defines how the EN pins function.
                https://www.aliexpress.com/item/3263...500004035517_1
                • marcelofct
                  • May 2019
                  • 122
                  • chile
                  thank for links
                  I removed PU19 and the short to ground is still on pin 10 and 4. Do I apply voltage to identify the short or not?
                  • marcelofct
                    • May 2019
                    • 122
                    • chile
                    I applied voltage and the cpu heats up
                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 02:20 PM
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                      HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                      This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      09-06-2024, 10:56 AM
                      HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                      This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                      HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
