MacBook Air A1466 820-00165-A no display
  • zmeutz
    • Nov 2016
    • 84
    I have an A1466 MacBook Air no display
    PPBUS_G3H - 7.86v
    G3 hot 3.48v
    Plt_rst 3.35v
    pp3v3 s0 3.35
    pp3v3 s3 3.35
    pp3v3 s4 3.35
    pp5v s0 5.31
    PP1V2_S5_SMC_VDDC 1.22v
    PP1V8_S3 1.8v
    PP5V_S0_CPUVR_VDD 5.12v
    PPVCC_S0_CPU 1.82v
    - computer starts
    - I have sound
    - caps lock led works, if I push it before sound it stay green, after it doesn't work
    - it can be closed from button
    Thanks!
    Stefan
  • mon2
    • 14662
    Re: MacBook Air A1466 820-00165-A no display
    Use your phone as a torch / flashlight and apply onto the backside / frontside to check if the display is working but your backlight is defective ?
    • zmeutz
      • Nov 2016
      • 84
      Display it's working, tested with other board, also backlight of display works…
      Backlight from board, work, because I see image changing in dark black when it starts…
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Usually its due to corroded/damaged backlit IC on A1466. Try reflowing the IC with a lot of flux if you see corrosion in the area. Else, you need to measure voltages here.
        • zmeutz
          • Nov 2016
          • 84
          are you talking about u7701?
          • reformatt
            • Feb 2020
            • 1495
            You need to ascertain whether it's actually booting (despite the fact you hear the chime). Best way is a with a Chipmunk USB tester (data light will flash green when ever the USB is probed for a boot device). If you don't have that, then look at the current draw via the Magsafe without battery connected. It should go over 600ma initially, then drop back to around 300ma or so when it's booted.
            If its booting, you should have 25V on C7797 for the backlight. If its 0V, then the fuse is probably blown. If it's 8.6V, then U7701 is usually the culprit.
            • zmeutz
              • Nov 2016
              • 84
              thanks!
              backlight ic was ...
              I replace 3 of them from donor boards but still no lock ... I took a new one and works like a charm ...
              I made also jumper to
              PPVOUT_SW_LCDBKLT_FB
              because on XW7720 was corrosion ...
              Thanks for help!
              Stefan
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Usually, U7701 doesnt work if you try to get it from donor board as its difficult to reball it. This IC is cheap-so always use new and its a easy fix.
