hp mini 210
  • Boxino
    • Feb 2022
    • 20
    • Zambia
    hp mini 210
    I have a hp 210 mini the problem is that it able to supply the 5v to the usb ports but it not able to read data and I can't transfer any file using the ports (an a newbi in laptop repair). have attached some photos and the schematic diagram.
  • mon2
    • Dec 2019
    • 14659
    Re: hp mini 210
    Does the same usb thumb drive work ok in another computer?
    Does the camera on this unit work properly?
    Do you have a usb keyboard or usb mouse for testing?
    • Boxino
      • Feb 2022
      • 20
      • Zambia
      Re: hp mini 210
      yes I tried using an external mouse and keyboard but its not responding but its able to charge the phone and if you connect an external hard drive the light turns on but its not flashing. in short it can not transfer data.
      • mon2
        • Dec 2019
        • 14659
        Re: hp mini 210
        What about the camera on this unit? Does it function?
        The camera is usb based.
        • Boxino
          • Feb 2022
          • 20
          • Zambia
          Re: hp mini 210
          i just checked it its not responding is saying "the screen resolution is too low for this app to run" I tried to update the drivers but its still giving the same error. and during the update of the drivers it gave an error that the windows os is not able to recognize the usb ports.
          • mon2
            • Dec 2019
            • 14659
            Re: hp mini 210
            See attached.
            There are a number of USB devices on this logic board. From your feedback, none of these devices are working so it is possible that the USB host function inside the Tiger chip is defective. Perhaps due to the lack of ESD protection devices on the logic board.
            The USB host function requires a 48 Mhz clock (sometimes 24 Mhz are used). Review if the 48 mhz clock is present and do check if the resistor @ R8057 is present and not defective. Check the resistance across R8057 as well.
            Perhaps the 48 mhz clock is absent or is defective and causing this fault.
            To check the USB data lines, remove all power, meter in DIODE MODE.
            Red meter probe, yes RED to GROUND (shield is ok).
            Black meter probe to USBP0+ on the USB connector or wherever you can probe it.
            What is the DIODE mode reading?
            Then repeat with USBP0- pin. Continue to test the other USB ports as well.
            If you have a bad DIODE mode reading then for sure your USB Host interface is damaged inside the TIGER IC.
            • Boxino
              • Feb 2022
              • 20
              • Zambia
              Re: hp mini 210
              i manage to troubleshoot the r8057 its okey and I managed to test the diode from the usb they are fine, but am having a challenge finding the tiger ic on the motherboard I tried searching for it using the schematic but I can't find the chip. I don't know if you can highlight it from the images I sent earlier.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Re: hp mini 210
                What @mon2 means by saying "TIGER IC" is the BGA chip.
                • Boxino
                  • Feb 2022
                  • 20
                  • Zambia
                  Re: hp mini 210
                  download the schematic diagram I sent earlier at the beginning of the chat the is a chip called the tiger ic but am having a challenge locating it on the motherbody. I sent some diagrams of the motherbody of the laptop but finding the chip is difficult cause I can't find the chip but I managed finding the resistor.
                  • wshadow
                    HP Mini 800 G5 - Transfer identity & WinLic between two mainboards
                    by wshadow
                    I got two HP Mini 800 G5 machines, both 65W mainboards (have all 12 FETs populated on the CPU power rail).
                    One board is always throwing errors in MemTest86, no matter which known good CPU/RAM combo installed. Board is fried. Period. Will be scrapped.
                    The defective board contains a Win10Pro license in BIOS.
                    The other board is working perfectly fine, but only includes a FreeDOS "license".
                    I want to transfer the Win10Pro license from the fried board to the working one. If that includes transferring S/N etc, I'm fine with that, will...
                    09-15-2025, 09:04 AM
                    HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                    This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-12-2024, 03:36 PM
                    HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                    This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                    09-12-2024, 02:20 PM
                    09-12-2024, 02:15 PM
                    HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
