MacBook 12" Retina 820-00045-A PP5V_S0 fluctuating
  • mferna14
    • Jun 2018
    • 1026
    Hi all., I am working on a MacBook 12" Retina Logic Board # 820-00045-A. It does not turn on. The Amp meter show 20v & the amps are around 0.01 ~ 0.05V . Upon checking all the power rails, till PP5V_S4 all is fine, getting full stable 5V on this rail but when I check PP5V_S0, it is fluctuating 5V , after a sec it goes to 0V & comes back again to 5v. This is happening continously. I checked for any short to GRD in diode mode but none. For where is this PP5V_S0 generated?? No liquid spill, logic board is very clean. Any help or tips will be great appreciated. Thanks
  • mon2
    • 14262
    Re: MacBook 12" Retina 820-00045-A PP5V_S0 fluctuating
    https://www.youtube.com/watch?v=F-sTAO9BEqE
    https://boards.rossmanngroup.com/thr...o-power.44744/
    What is the voltage of PPBUS_G3H ?
    • mferna14
      • Jun 2018
      • 1026
      Thank you so very much mon2 for all rescue of mine & infact ours.... Anyway all done, had to re-flow the U7600 (U7600 SN650801 Power management IC) & all worked. Signal is generated from this chip P5VS0_PHASE... Since the balls under the chip had loose connection this is why PP5V_S0 was coming & going away contin'. After a good re-flow all worked fine. Thanks for the help.
