iPad pro A1652
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    iPad pro A1652
    hello,
    does anyone have schematic and boardview for iPad pro A1652.
    i have problem with no image and backlight.
    before the 0.7 ohm coil for image was burnt and i replace with coil from iphone 6 but it burnt again, and i replaced with coil from 6s plus but now no image at all. please advice
  • mon2
    • Dec 2019
    • 14420
    Re: iPad pro A1652
    What is the current draw? Perhaps the backlight fuse or backlight IC is now defective?
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      Re: iPad pro A1652
      hi @mon2,
      current draw on usb meter 1,8 amps and i hear ding sound.
      backlight fuse is beep when test with continuity mode
      • mon2
        • Dec 2019
        • 14420
        Re: iPad pro A1652
        https://www.youtube.com/watch?v=jhbr4qVc65Q
        Check for missing / defective parts in the attached pic.
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          Re: iPad pro A1652
          already check, filters and coils are ok.
          or maybe the amps of the coil i changed is different?
          • mon2
            • Dec 2019
            • 14420
            Re: iPad pro A1652
            Yes, be sure to use the proper rated coils. Not sure if the parts you have applied are able to handle the required current. Start with replacing them again but with confirmed higher current components. Vipphonefix and similar shops in China sell coil and diode kits for this type of work. Confirm before buying.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              Re: iPad pro A1652
              do you know the amps value of these coils for backlight and image? because from the picture it only shows the value in ohms
              • mon2
                • Dec 2019
                • 14420
                Re: iPad pro A1652
                Remove all power.
                Do connect the lcd display.
                Meter in resistance mode. Measure the resistance to ground of the coil that was burnt and do measure each side of this coil to ground. This is to confirm there is no short.
                Review this great article from Jessa:
                https://www.ipadrehab.com/article.cfm?ArticleNumber=7
                • kingskie
                  • Oct 2014
                  • 249
                  • indonesia
                  Re: iPad pro A1652
                  update:
                  i changed the flexible and the image and backlight is ok except for touch...sigh.
                  checked filters and coils all are ok.
                  any suggestion?
                  • mon2
                    • Dec 2019
                    • 14420
                    Re: iPad pro A1652
                    Fault may be with the touch IC but first watch the related videos from Alex at Northridge repair on this topic.
                    http://www.elemasterxu.com/store/BCM...ouch%20ic.html
                    https://youtu.be/FTHU7MD2rTA
                    https://youtu.be/tSTpd6M1Ep0
                    • kingskie
                      • Oct 2014
                      • 249
                      • indonesia
                      Re: iPad pro A1652
                      update:
                      i decided to resolder the flexible and the touch is ok now.
                      thanks @mon2
                      • mon2
                        • Dec 2019
                        • 14420
                        Re: iPad pro A1652
                        Good job 👌
                        Thanks for your update for the thread closure.
                        • GeirAndersen
                          iPad .pcb file collection
                          by GeirAndersen
                          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                          IPAD COLLECTION 1
                          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                          12-09-2024, 09:28 AM
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • Mogli1476
                          Ipad Pro A1652 12.9" Schematic + Board View needed 820-00301-A
                          by Mogli1476
                          Hey @all,
                          my ipad Pro dont want to work anymore. I measured the incoming amps which is approx. 0.5A. Then I changed the Tristar IC and blow out some parts near this IC. Now I want to find the missing parts. Thats why i´m asking for the schematics & board view for this ipad pro.
                          Thank for your help!
                          Best regards, Mike​
                          05-06-2024, 03:15 PM
                        • Mogli1476
                          by Mogli1476
                          Hey @all,
                          820-00301-A
                          Best regards, Mike
                          03-01-2024, 05:46 AM
                        • Mogli1476
                          by Mogli1476
                          Hey @all,
                          Best regards, Mike
                          02-24-2024, 02:57 PM
