Lenovo s340 15IIL FL5C5/FL535/FL435 LA-H103P
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi
    The laptop power on, fan starts and stop. Power on light remain. But the laptop does not start
    Witout ram, no beep.
    When off, I see 5v on one coil, but i dont see 3.3
    When on, i see 5v, 3.3v, 1.2v, 1.8v
    Can you help me inspect it?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo s340 15IIL FL5C5/FL535/FL435 LA-H103P
    Cpu Vcroe present?? VCCSA present?? DRAMRST# present?? have you flashed bios??
    • koby058
      • Jan 2017
      • 387
      • israel
      Hi, did not try bios, should i first try bios ?
      How can i measure those?
      attached the board photo
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        DRAMRST#-check it on pin108 of ram slot.
        Strongly recommend to flash clean me bios and remember to take backup of original file. If you dont have access to bios file, post your backup bios in "Bios Section" and ask for clean me fresh bios.
        Vcore coil is located on top side of the cpu-the biggest in size.
        • koby058
          • Jan 2017
          • 387
          • israel
          hi
          thanks for reply
          I have try a bios and got same behavior.
          as i mention the 5v was present but the 3.3v was only present when The laptop is powered on.
          now, the 5v also missing and i have a chip that is getting very very hot when i plug the charger
          I could not recognize it, attached a photo.
          How can i proceed here ?
          • mon2
            • Dec 2019
            • 14628
            https://www.badcaps.net/forum/showpo...1&postcount=12
            Part is Silergy SY8386BRHC.
            https://www.aliexpress.com/item/1005...d=2Jci72gHwCWo
            Attached documents are from another s340 schematic but should be similar to yours.
            • koby058
              • Jan 2017
              • 387
              • israel
              Thank you, Do yo think its related to the absent of the 3.3ALW ?
              • mon2
                • Dec 2019
                • 14628
                Yes. See the another view of the same regulator.
                Suggestions:
                1) Remove all power -> meter in resistance mode. Check the resistance to ground of PL402 - either side of the inductor.
                What is the resistance reading? (and scale used on your meter for this test)
                2) Based on your post, if the regulator is hot then it is likely defective. With patience, flux and enough heat and low air pressure -> remove this regulator and check the resistance to ground of the same PL402 inductor.
                If the resistance is low then there is some defective component on this rail. If practical, you can lift up PL402 with enough heat & flux but with care so that the PCB pad does not get torn off the PCB. Then measure again. This method will allow you to determine if this regulator or consumer (downstream) rail is the fault of the low resistance.
                Better idea...remove the solder blob @ PJ401 -> then check the resistance to ground on EACH side of this removed solder blob. Then you will know if the producer (regulator) or the consumer (downstream) is the reason for this low resistance / root cause of the regulator to be heating up or damaged.
                Also...check the voltage levels on EN1 and EN2. Only if they are high (~3v3) then the regulator will turn on.
                • koby058
                  • Jan 2017
                  • 387
                  • israel
                  Will take me time, i will update here
                  If you look on the photo you will see the regulator is blowned
                  • koby058
                    • Jan 2017
                    • 387
                    • israel
                    Hi, i have replaced this SY8386BRHC from donner board, i hav 4.5v on en1 and 0 on en2, how can i proceed?
                    • koby058
                      • Jan 2017
                      • 387
                      • israel
                      Where ENLDO_5V3v comes from to pin 9 (EN2)?
                      • mon2
                        • Dec 2019
                        • 14628
                        See attached.
                        1) EN2 = based on 2 resistors acting like a voltage divider. They accept the rather high adapter voltage of ~19V and lower it to a safe value using the resistors to create the EN2 enable signal.
                        If EN2 = 0v then it is possible that B+ is absent. Confirm it.
                        2) Check the power path attachment on how the voltage should travel onto your logic board onto B+.
                        • koby058
                          • Jan 2017
                          • 387
                          • israel
                          since i have the 5vALW can i assume B+ is present ?
                          if only i can find PR402 and measure it. i can only see pr404 and PC430 both have no voltage and then i see a via nothing on the other side.
                          I have measured resistance to ground on PC430 and got 0.72M ohm
                          • mon2
                            • Dec 2019
                            • 14628
                            What is the resistance across PR404 ?
                            • koby058
                              • Jan 2017
                              • 387
                              • israel
                              40k
                              • mon2
                                • Dec 2019
                                • 14628
                                This value does not match the other schematic of the S340 but proceed to post a close pic of the other side of the PCB where PU401 resides.
                                There has to be another resistor somewhere on this board that is used to enable the EN2 signal.
                                • koby058
                                  • Jan 2017
                                  • 387
                                  • israel
                                  Is this one good?
                                  • mon2
                                    • Dec 2019
                                    • 14628
                                    Actually meant to flip the board so we can view the bottom side.
                                    Before you do that, check the resistance of each black resistor surrounding the PU401 IC.
                                    Any of them with a high enough resistance to be the part we are hunting for?
                                    • koby058
                                      • Jan 2017
                                      • 387
                                      • israel
                                      I have neasured around and did not find very high resistance, most was up to 120k
                                      Attached other side photo
