A1466 820-00165 no display
  • guruji
    • Oct 2012
    • 118
    • India
    Hello
    I have a a1466 motherboard and the power rails seem to be fine
    3.3v okay
    5v okay
    G3 hot 3.42v
    Ram 1.2v okay
    1.05v also okay
    Cpu core 1.809v
    Plt_rst 3.3v okay
    I have flashed the bios and firmware but nothing also used a working donor smc
    So my question is that once we get plt reset should the display come on
  • mon2
    • Dec 2019
    • 14001
    Re: A1466 820-00165 no display
    1) you should be sleeping
    2) any fan spin?
    3) keyboard caps LED on? does it toggle?
    4) What is the voltage of PPBUS_G3H ?
    • reformatt
      • Feb 2020
      • 1400
      Usually I look at activity around U6100 to see if the BIOS is being loaded first (check clocks etc for activity). Current via Magsafe is a good indication of whether it's at least attempting to boot.
      I've also had recently a board where the AUD_SPI_MOSI/AUD_SPI_MOSO/AUD_SPI_CLK pull ups (R1661/R1662/R1663) had corrosion on them. The main issue was R1663 had corroded and just fell off. Current for the board via Magsafe was about 0.3A and not varying.
      I point this out since these lines go straight to the CPU, and obviously are interrogated during the boot process. So check all your data lines in/out of the CPU for any corrosion etc.
      • guruji
        • Oct 2012
        • 118
        • India
        yes thanks I know it was late to put a post but that is the only time i get to put it on board
        2) any fan spin? yes it does spin but like 2 sec delay when power is pressed
        3) keyboard caps LED on? does it toggle? no at all
        ppbus is 8.5V normal also battery is charging.
        • guruji
          • Oct 2012
          • 118
          • India
          some how i feel the activity on the bios is not right.The cpu is probably not reading the ME codes.
