ThinkPad T460s processor frequency i5-6300U
  • bykanovm
    • Aug 2022
    • 95
    • Украина
    Good afternoon. There is Lenovo ThinkPad T460s, NM-A421 rev 3.0 platform with i5-6300U processor. The problem is that the processor runs at a minimum frequency of 0.39 Ghz. Who knows what could be the problem? Faced this on DELL laptops when connecting the wrong charger. Haven't seen this on Lenovo. What is responsible for the CPU clock rate on a ThinkPad?
  • mon2
    • 13908
    Re: ThinkPad T460s processor frequency i5-6300U
    Yes, can be impacted in the same way..
    From the linked wikipedia:
    Signal Pin
    Power controller subsystem senses when power is connected, and measures resistance between central signal pin and ground. Firmware policy might reduce performance (battery charges slowly, processors throttle to low speed) if an insufficient supply is detected. This issue is discussed at forum.thinkpads.com, "W520 requires 170W AC adapter".
    power rating resistance
    65 W 10 kΩ
    90 W not connected
    135 W 0 Ω
    170 W 1.5 kΩ
    https://www.thinkwiki.org/wiki/Power_Connector
    • bykanovm
      • Aug 2022
      • 95
      • Украина
      Checked the entire ACDC_ID line. All resistor values are correct. Reached the MEC1653 multicontroller. I think it's in him. I'll try to flash different BIOSes, but I doubt that they are the case.
      • mon2
        • 13908
        What is the resistance value you measured of this ID pin on the adapter being tested?
        Take the measurement without any power to the adapter.
        • bykanovm
          • Aug 2022
          • 95
          • Украина
          The resistance on the bottom contact without the connected adapter is 10 Ком and smoothly increases to 17 Ком. With connected adapter without power supply, resistance 0, short to ground. When applying power, the voltage on this contact is 1.3 V. The resistance of the R258 resistor is 750 Ω, which corresponds to the nominal value in the scheme. The resistor R2090 caused suspicion, its resistance on the board is 75 Ком, although according to the scheme it should be 10 Ком. Changed it to a 10 Ком resistor, nothing changed. The battery is recognized, but when the power supply is turned off, the laptop also turns off immediately, although the battery is fully charged.
          • mon2
            • 13908
            Can you post or link the schematic if on this forum?
            When you run from the battery only, the logic board is stable and running at the right speed?
            • bykanovm
              • Aug 2022
              • 95
              • Украина
              The laptop does not work from the battery, it immediately turns off when the power supply is turned off. Here is a link to a thread with a diagram.
              https://www.badcaps.net/forum/showth...hlight=nm-a421
              • mon2
                • 13908
                Is the battery a known good battery?
                Remove the battery. Attach only the power adapter.
                Meter in dc volts mode (20v or higher).
                Red meter probe on ACOK (pin 5) of charger IC (pu101). Black meter probe to ground.
                What is the reading?
                • bykanovm
                  • Aug 2022
                  • 95
                  • Украина
                  PU101? I don't see that. The voltage is exactly 20V. Served from the laboratory unit and from the power supply, does not stick. Accumulators judging by the consumption of the laboratory unit are not charged. Also, AIDA64 cannot recognize either of the two batteries. The batteries themselves are original.
                  • bykanovm
                    • Aug 2022
                    • 95
                    • Украина
                    I guess you meant U1
                    • bykanovm
                      • Aug 2022
                      • 95
                      • Украина
                      On the fifth leg of U1 (BQ24780SRUY) ACOK signal Stable 3.2V
                      • mon2
                        • 13908
                        I think we are referencing 2 different schematics. The first link in the shared webpage (Alisaler) has a different schematic than the one in the last post of the same webpage.
                        Which schematic is matching yours?
                        • bykanovm
                          • Aug 2022
                          • 95
                          • Украина
                          Last link. It matches my board
                          • mon2
                            • 13908
                            Remove the adapter and using the battery only, measure the voltage on each pin of Q8, Q34 and Q13. Post your readings.
                              Lenovo ThinkPad T460s Grade T1A Notebook T Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad T460s Grade T1A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s Grade T1A boardview and T460s Grade T1A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 08:47 AM
                              Lenovo ThinkPad T460s Notebook T Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad T460s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s boardview and T460s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                              09-06-2024, 06:17 AM
                              Lenovo ThinkPad T460s Ultrabook T Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad T460s Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s boardview and T460s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                              09-06-2024, 06:11 AM
                              09-06-2024, 06:38 AM
                              09-06-2024, 06:34 AM
